| 0001195 | Draft | Bug | public | 2013-08-05 19:22 | 2013-08-09 23:02 |
| Reporter | nahshon | Assigned To | yorik | ||
| Summary | 0001195: Open DXF - exception when opening file created with Inkscape | ||||
| Description | File saved from Inkscape using the "Better DXF Output" filter. File can be open with other programs: pycam, f-engrave, heekscad. | ||||
| Additional Information | Exception message: opening /home/itai/Hello.dxf... Traceback (most recent call last): File "<string>", line 1, in <module> File "/home/itai/FreeCAD-src/build/Mod/Draft/importDXF.py", line 1185, in open processdxf(doc,filename) File "/home/itai/FreeCAD-src/build/Mod/Draft/importDXF.py", line 787, in processdxf drawing = dxfReader.readDXF(filename) File "/home/itai/.FreeCAD/dxfReader.py", line 375, in readDXF obj.data = objectify(obj.data) File "/home/itai/.FreeCAD/dxfImportObjects.py", line 1305, in objectify objects.append(type_map[item.type](item)) File "/home/itai/.FreeCAD/dxfImportObjects.py", line 904, in __init__ self.flags = obj.get_type(70)[0] <type 'exceptions.IndexError'>: list index out of range | ||||
2013-08-05 19:22
Interesting, there seems to be some entity not supported by the dxfparser. I'll have a look at that... |
Ok this is fixed now. You need to delete the file ~/.FreeCAD/dxfImportObjects.py so it will be downloaded again on next run. |
| 2013-08-05 19:22 | nahshon | New Issue | |
| 2013-08-05 19:22 | nahshon | File Added: Hello.dxf | |
| 2013-08-05 22:19 | yorik | Note Added: 0003439 | |
| 2013-08-05 22:19 | yorik | Status | new => assigned |
| 2013-08-05 22:19 | yorik | Assigned To | => yorik |
| 2013-08-09 23:02 | yorik | Note Added: 0003445 | |
| 2013-08-09 23:02 | yorik | Status | assigned => closed |
| 2013-08-09 23:02 | yorik | Resolution | open => fixed |
| 2013-08-09 23:02 | yorik | Fixed in Version | => 0.14 |
| 2013-08-09 23:02 | yorik | Project | Sketcher => Draft |
