| 0001206 | FreeCAD | Feature | public | 2013-08-09 14:17 | 2013-09-21 11:19 |
| Reporter | oldestfox | Assigned To | |||
| Summary | 0001206: Sketcher select tool (hand with pointing finger) | ||||
| Description | Make the select bi-directional. i.e. If moved from right to left it will select all objects "fully in" the box. If moved from left to right, it will select all objects "cut" by the box. (or vice-versa) The above would apply in the vertical direction either up or down. | ||||
| duplicate of | 0000462 | closed | Sketcher | Sketcher: allow box selection |
In AutoCAD and IntelliCAD products this is called window selection. My humble suggestion is that when selecting objects via a selection window by clicking left-to-right, the edges of the selection window appear as solid lines, and only objects wholly inside the selected window are chosen. When objects are selected via a selection window by clicking right-to-left, the edges of the selection window appear as dotted lines, and objects wholly inside the selection window AND objects that cross the selection window are selected. EDIT================ Or perhaps make the window behavior changeable by the user END EDIT====================== Just my two cents worth. This method of selecting objects is very handy for moving and stretching objects. |
This is the same as ticket 0000462: http://sourceforge.net/apps/mantisbt/free-cad/view.php?id=462 |
Close it because it's a duplicate |
| 2013-08-09 14:17 | oldestfox | New Issue | |
| 2013-08-17 17:10 | bejant | Note Added: 0003488 | |
| 2013-08-19 00:19 | bejant | Note Edited: 0003488 | |
| 2013-09-15 10:34 | bejant | Note Added: 0003583 | |
| 2013-09-21 11:18 | wmayer | Relationship added | duplicate of 0000462 |
| 2013-09-21 11:19 | wmayer | Note Added: 0003603 | |
| 2013-09-21 11:19 | wmayer | Status | new => closed |
| 2013-09-21 11:19 | wmayer | Resolution | open => duplicate |
