| 0001219 | FreeCAD | Bug | public | 2013-08-16 11:08 | 2013-12-20 21:23 |
| Reporter | oghamthebold | Assigned To | yorik | ||
| Platform | PC | OS | Windows 7 | OS Version | 64-bit |
| Summary | 0001219: Zero width rectangle (i.e. 2 vertical points) odd behaviour + crash | ||||
| Description | See steps to reproduce. | ||||
| Steps To Reproduce | (a) Create zero width rectangle (i.e. using 2 vertical points). Note: This creates an inverted rectangle with width set to height. (b) Undo. (c) Repeat step (a) Crash always. | ||||
| Additional Information | Maybe a 0 width rectangle is not allowed - but is the default to create a square (using the height instead of the specified width)? Obviously using 2 vertical points is something only the uninitiated would try - while 'learning' - which I am / did do. | ||||
Hm I can't reproduce this, for me trying to create a zero-width rectangle gives the default square, but doesn't crash... What is your version of FreeCAD? (paste here the contents of the help->About freecad dialog) |
Thanks - in Mantis (i.e. the bug tracker) - click 'View Advanced' to see; FreeCad build version and steps to reproduce |
Hah thanks.. nobody fills these fields, I never think to look at them Anyway I still cannot reproduce this crash.. I might have made some changes since version 0.13 that fixed the problem, but I can't remember. Can I ask you to try a 0.14 version from https://sourceforge.net/projects/free-cad/files/FreeCAD%20Windows/ ? |
Closing this because there is no more feedback... |
| 2013-08-16 11:08 | oghamthebold | New Issue | |
| 2013-08-16 18:37 | yorik | Note Added: 0003483 | |
| 2013-08-16 18:37 | yorik | Status | new => assigned |
| 2013-08-16 18:37 | yorik | Assigned To | => yorik |
| 2013-08-16 18:37 | yorik | Status | assigned => feedback |
| 2013-08-17 15:20 | oghamthebold | Note Added: 0003486 | |
| 2013-08-17 15:27 | yorik | Note Added: 0003487 | |
| 2013-12-20 21:23 | yorik | Note Added: 0003959 | |
| 2013-12-20 21:23 | yorik | Status | feedback => closed |
| 2013-12-20 21:23 | yorik | Resolution | open => fixed |
| 2013-12-20 21:23 | yorik | Fixed in Version | => 0.14 |
