| 0001225 | Sketcher | Bug | public | 2013-08-19 18:38 | 2015-01-02 20:49 |
| Reporter | bejant | Assigned To | wmayer | ||
| Summary | 0001225: Allow User to Rotate Arc Radius Constraint Text and Leader | ||||
| Description | After adding a constraint to a circle, the constraint text and arrow can be rotated about the circle and can also be moved radially. However after adding a radius constraint to an arc the constraint text can only be moved radially towards or away from the center of the arc; the user is unable to rotate the text about the arc. For simple sketchers this is not a problem but for more complex sketchers text is sometimes atop one another. The attached avi is a 10 second screencast of this issue. OS: Windows XP Platform: 32-bit Version: 0.14.2370 (Git) Branch: master Hash: a836759ebd91404954a778ff8885e152611576e1 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 | ||||
My apologies; it seems the file did not attach, Here's a link to it: https://www.dropbox.com/s/wt708qv892uijc0/FC%20014%20Radius%20Constraint.avi |
I agree. It is inconvenient, and looks like a bug because circles do allow the dimension lines to be rotated. (found with version 0.14 2370, running on Windows 7, in Touchpad navigation mode) |
| 2013-08-19 18:38 | bejant | New Issue | |
| 2013-08-19 18:42 | bejant | Note Added: 0003498 | |
| 2013-08-30 11:57 | axiomaticbiz | Note Added: 0003533 | |
| 2015-01-02 20:49 | wmayer | Changeset attached | => FreeCAD Master master 08828e5d |
| 2015-01-02 20:49 | wmayer | Assigned To | => wmayer |
| 2015-01-02 20:49 | wmayer | Status | new => closed |
| 2015-01-02 20:49 | wmayer | Resolution | open => fixed |
