| 0001242 | FreeCAD | Bug | public | 2013-09-13 10:55 | 2013-11-10 19:22 |
| Reporter | ulrich1a | Assigned To | yorik | ||
| Summary | 0001242: Draft Dimensions due not observe Dimension Precision on FreeCAD Windows | ||||
| Description | In the Windows-Version of FreeCAD the Draft-Dimensions are pretty useless, as the Dimension length is always truncated to an integer, regardless of the setting in the preferences. An override could be a workaround, but overrides are not transferred to a drawing page. The last point is also valid for the linux-version. | ||||
| Additional Information | Tested with FreeCAD 0.13 stable and FreeCAD Version: 0.14.2497 (Git) on Windows 32 bit. | ||||
Okay I'll fix the override not appearing on the drawing page For the other problem, I need more info... Unfortunately I have no windows installation to test. Are all dimensions shown as integer values? It is strange, nobody ever reported that... Changing the "Dimension precision level" value in Draft preferences has no effect? |
I did an additional test with FreeCAD 0.13 on Windows XP at home. There is always an integer shown as long as the Draft preferences are not saved. The draft dimension preferences show a default precision of 2 in the preferences. If I do not confirm this setting by ok, then I still get integers. But changing and saving the precision level indeed gives me now dimension numbers with decimals. I will test again next week on Windows 7. |
Yes that is normal... You must save/apply the preferences. Then probably it is the default value that is wrong, I'll fix that. |
I'm unable to recreate ulrich1a's problem, even if I change Edit -> Preferences -> Draft (from the left side of the window) -> General Settings tab -> Dimensions Precision Level and do not hit the Apply button at all and instead hit the OK button, the dimension precision is saved. Link to video showing what I did: https://www.dropbox.com/s/1vp1a2y8cgsyb4j/20130916c%20Dimension%20Precision.avi OS: Windows XP Platform: 32-bit Version: 0.14.2370 (Git) Branch: master Hash: a836759ebd91404954a778ff8885e152611576e1 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 |
I did a little bit of investigation. The problem is related to https://sourceforge.net/apps/mantisbt/free-cad/view.php?id=1241 I could not set the Dimension Precisions Level. Every time a visited the Draft Preferences and klicked OK, I could not add a Dimension without a crash of FreeCAD. This seems to be related to Windows 7. The same binaries worked well under Wine! FreeCAD git 2512 under Windows 7 crashed at adding a Dimension, when the Draft Preferences where set with pushing the ok-button. I could solve this for me under Windows 7. I installed the osifont, and copied it also to a path, I could enter in FreeCAD in the Draft Preferences. I than put "osifont" as the default in the Draft Preferences for the standard font and the path to the copied osifont at Default Shape Font File. I dont know, what of the two things I made, solved the problem. This may be investigated by someone how is more familiar with windows 7. Now it works like expected. |
The default font is now the internal coin font, which should prevent FreeCAD from crashing. |
| 2013-09-13 10:55 | ulrich1a | New Issue | |
| 2013-09-13 15:12 | yorik | Status | new => assigned |
| 2013-09-13 15:12 | yorik | Assigned To | => yorik |
| 2013-09-13 15:14 | yorik | Note Added: 0003571 | |
| 2013-09-13 17:41 | ulrich1a | Note Added: 0003574 | |
| 2013-09-13 17:55 | yorik | Note Added: 0003575 | |
| 2013-09-17 00:20 | bejant | Note Added: 0003590 | |
| 2013-09-17 12:35 | ulrich1a | Note Added: 0003592 | |
| 2013-11-10 19:21 | yorik | Relationship added | child of 0001241 |
| 2013-11-10 19:22 | yorik | Note Added: 0003880 | |
| 2013-11-10 19:22 | yorik | Status | assigned => closed |
| 2013-11-10 19:22 | yorik | Resolution | open => fixed |
| 2013-11-10 19:22 | yorik | Fixed in Version | => 0.14 |
