0001243FreeCADBugpublic2013-10-01 08:13
Reporterchristianlupus Assigned To
PrioritynormalSeveritytrivialReproducibilityalways
Product Version0.13
Summary0001243: Missing linking option in drawing branch to SoQt
DescriptionI cloned the git repositry and tried to build the drawing branch (like here: http://freecad-tutorial.blogspot.de/).
There arose the problem that the linking of bin/FreeCAD failed due to many missing references to methods in libSoQt.so. I then modified the file 'src/Main/CMakeFiles/FreeCADMain.dir/link.txt' and added "-lSoQt" to the options. Now FreeCAD linked. Unfortunately I am not common with cmake so it is impossible for me to correct the source files to insert that linking flag by default. Maybe someone common to cmake can handle this.
Additional InformationUbuntu raring amd64
2013-09-21 11:16
administrator   ~0003602
I wonder if your build got corrupted somehow.
christianlupus
2013-10-01 07:57
reporter   ~0003704
I tried to rebuild and it worked now. Maybe there were some problems with dependencies.
2013-10-01 08:13
administrator   ~0003705
Maybe there was a mix-up somehow. Usually when setting a dependency to a library in a CMake file A then this dependency will be copied to the CMake file B if it depends on A.
2013-10-01 08:13
administrator   ~0003706
So, I close this one.
2013-09-16 05:29 christianlupus New Issue
2013-09-21 11:16 wmayer Note Added: 0003602
2013-10-01 07:57 christianlupus Note Added: 0003704
2013-10-01 08:13 wmayer Note Added: 0003705
2013-10-01 08:13 wmayer Note Added: 0003706
2013-10-01 08:13 wmayer Status new => closed
2013-10-01 08:13 wmayer Resolution open => no change required
