| 0001250 | FreeCAD | Bug | public | 2013-09-24 14:51 | 2014-01-18 11:35 |
| Reporter | pkoning | Assigned To | |||
| Summary | 0001250: Boolean operations seem surprisingly slow | ||||
| Description | I'm doing a bunch of CSG using the Python API. A lot of that involves extruding components, then using "fuse" to combine them, and "common" to trim them to the right shape. Some of these operations take a very long time. For example, the final step is a common of a shell made up of 18 parts, which has a total of 552 faces, with a solid to trim it; that solid has 18 faces. The operation works fine, but it takes about 55 seconds. The resulting trimmed shape has 466 faces. I could understand this taking a fair fraction of a second, but nearly a minute seems very strange. | ||||
Well, this is something we have not under control. However, with a newer version of OpenCascade a few people reported that boolean operations are much faster now. See also: http://opencascade.blogspot.de/2008/12/why-boolean-operations-are-so-sloooooow.html Nevertheless, I fear to close this "bug" as not fixable because this is not in our hand. |
Very strange. It's not as if boolean operations are NP-complete! I suppose it involves operations on all the pairs of faces of the two objects, but that's only 10,000 or so total. How does one use up 10 ms per face pair on a modern processor that executes several million instructions in that time? |
Since you are doing CSG modelling you can also have a look at OpenSCAD. In FreeCAD this is already integrated and you can use the GUI therefore. |
As said earlier it's not in our hands to optimize the boolean operations. So I'll close it as unfixable. |
| 2013-09-24 14:51 | pkoning | New Issue | |
| 2013-09-25 09:32 | wmayer | Note Added: 0003659 | |
| 2013-09-25 22:45 | pkoning | Note Added: 0003671 | |
| 2014-01-18 11:33 | wmayer | Note Added: 0004094 | |
| 2014-01-18 11:35 | wmayer | Note Added: 0004095 | |
| 2014-01-18 11:35 | wmayer | Status | new => closed |
| 2014-01-18 11:35 | wmayer | Resolution | open => won't fix |
