| 0001251 | Assembly | Bug | public | 2013-09-24 15:56 | 2015-02-03 16:11 |
| Reporter | project4 | Assigned To | ickby | ||
| Summary | 0001251: Deleting the product node in the model tree cause havoc | ||||
| Description | When moving to assembly workbench, the model tree automatically creates structure of: Application => Assembly1 => Product Deleting the Product entry and after that move to the PartsDesign workbench cause the application to crash or behave strangely. I think that evrey workbench should somehow determine what it relevant for it and what is not. I think it's related to the same issue, if not, will open another bug entry, but when trying to open the fcstd file saved with assembly on the PartsDesigner workbench, it also crashes. | ||||
| Additional Information | when not deleting the "product" entry and moving to the PartsDesigner, I see that more nodes are added to the model: "Origin" folder, "Body" object and "NonBodyFeatures" folder where the assembly's "product" is moved to. As I wrote, I think that "Assembly" tree should not be touched by the PartsDesigned workbench, it should create it's own tree model under "Application". I'm on latest assembly stream. OS: Ubuntu 13.04 Platform: 64-bit Version: 0.14.2654 (Git) Branch: jriegel/dev-assembly Hash: 3d4dd4f64f24255dbaec25767cff7b74bb98fc6d Python version: 2.7.4 Qt version: 4.8.4 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 | ||||
Correction: when openning assembly's file in PartsDesigner I get the following dialog box: No body was found in this document, and none could be created. Please report this bug.We recommend you do not use this document with the PartDesign workbench until the bug has been fixed. |
I can reproduce your first report (crash after deleting the product), however, not the second one (crash by open assembly file while in partdesign). Can you elaborate a bit more on this? maybe give a file which crashes? |
I've added a correction after submitted the bug, when opening the assembly file in PartDesigner it pops a dialog with the following text: No body was found in this document, and none could be created. Please report this bug.We recommend you do not use this document with the PartDesign workbench until the bug has been fixed. Will upload the file in a moment. Maybe you have it fixed in your stream already... I'm on jriegel/dev-assembly branch. |
I see the dialog popup in ickby's assembly stream as well. |
the crash is fixed in the assembly branch of git@github.com:ickby/FreeCAD_constraint.git you can now delete any product and close the documents without crash. The popup still won't appear for me. |
obsolete |
| 2013-09-24 15:56 | project4 | New Issue | |
| 2013-09-24 15:58 | project4 | Note Added: 0003647 | |
| 2013-09-24 17:21 | ickby | Note Added: 0003649 | |
| 2013-09-24 18:39 | project4 | Note Added: 0003654 | |
| 2013-09-24 18:40 | project4 | File Added: assembly.fcstd | |
| 2013-09-25 13:42 | project4 | Note Added: 0003667 | |
| 2013-10-24 17:28 | ickby | Note Added: 0003802 | |
| 2013-11-04 12:50 | yorik | File Deleted: assembly.fcstd | |
| 2013-11-04 12:50 | yorik | File Added: assembly.fcstd | |
| 2015-02-03 16:11 | ickby | Note Added: 0005759 | |
| 2015-02-03 16:11 | ickby | Status | new => closed |
| 2015-02-03 16:11 | ickby | Assigned To | => ickby |
| 2015-02-03 16:11 | ickby | Resolution | open => fixed |
