| 0001252 | Assembly | Bug | public | 2013-09-24 16:09 | 2015-01-08 06:56 |
| Reporter | project4 | Assigned To | jmaustpc | ||
| Summary | 0001252: Creating assembly on a file created from PartsDesigner | ||||
| Description | Start in PartsDesigner workbench, create a new document. Now move to assembly workbench. Trying to add existing component doesn't work. Pressing on "Add new component" toolbar adds "Product_0" to the model tree. Selecting the "Product_0" and pressing "add existing component" opens the dialog to select STP file, selecting one and pressing Open creates STP_Part_1 entry on the same level as the Product_0, while I would expect it to be placed in the Product_0 as its parent entry. No models are shown, only the initial sketch axis from the PartsDesigner. Something gets wrong with the model tree in that case. I've tried to add a new document from the assembly workbench, while this one is open, than the second file behaves the same problematic way. | ||||
| Additional Information | Console have some traceback printouts: Traceback (most recent call last): File "<string>", line 1, in <module> File "/home/alex/Workspace/FreeCad/assembly/Mod/Assembly/AssemblyLib.py", line 70, in importAssembly DestItem.Items = DestItem.Items + [po] <type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'Items' Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> File "/home/alex/Workspace/FreeCad/assembly/Mod/Assembly/AssemblyLib.py", line 70, in importAssembly DestItem.Items = DestItem.Items + [po] Traceback (most recent call last): File "<string>", line 1, in <module> File "/home/alex/Workspace/FreeCad/assembly/Mod/Assembly/AssemblyLib.py", line 70, in importAssembly DestItem.Items = DestItem.Items + [po] <type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'Items' Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> File "/home/alex/Workspace/FreeCad/assembly/Mod/Assembly/AssemblyLib.py", line 70, in importAssembly DestItem.Items = DestItem.Items + [po] Traceback (most recent call last): File "<string>", line 1, in <module> File "/home/alex/Workspace/FreeCad/assembly/Mod/Assembly/AssemblyLib.py", line 70, in importAssembly DestItem.Items = DestItem.Items + [po] <type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'Items' Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> File "/home/alex/Workspace/FreeCad/assembly/Mod/Assembly/AssemblyLib.py", line 70, in importAssembly DestItem.Items = DestItem.Items + [po] I'm on latest assembly branch. OS: Ubuntu 13.04 Platform: 64-bit Version: 0.14.2654 (Git) Branch: jriegel/dev-assembly Hash: 3d4dd4f64f24255dbaec25767cff7b74bb98fc6d Python version: 2.7.4 Qt version: 4.8.4 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 | ||||
I fixed this in the assembly branch of git@github.com:ickby/FreeCAD_constraint.git |
I'm currently on jriegel/dev-assembly, should I use your branch instead or the one I use should aggregate all your changes as well after a while? |
My branch will be merged from time to time into jriegel/dev-assembly, however, I can't say when this happens as this is jriegels branch and he does the merging. You can use my branch, as jriegel is not activly developing at the moment and therefore you will miss nothing. That can of course change any time :) |
OK, will move to yours. Thanks. |
I'm not sure whether I cloned the right repository... Trying git clone git@github.com:ickby/FreeCAD_constraint.git assembly_ickby I get: Permission denied (publickey). fatal: Could not read from remote repository. Please make sure you have the correct access rights and the repository exists. I've found another repository with your branch name: git clone https://github.com/ickby/FreeCAD_constraint.git assembly_ickby But after compiling I see the old assembly module with only 1 button in the toolbar... Can you please guide me how to clone your branch? Thanks. |
you need the "assembly" branch, clone the repository and checkout the branch after that. do git clone https://github.com/ickby/FreeCAD_constraint.git assembly_ickby cd assembly_ickby git checkout assembly it's basicaly the same if you switch git@github.com:ickby/FreeCAD_constraint.git for https://github.com/ickby/FreeCAD_constraint.git To see which branches are available after cloning type "git branch". You can also addd the repository as remote to make later updates easyer: git remote add ickbys_repo https://github.com/ickby/FreeCAD_constraint.git ans later for updating: git pull ickbys_repo assembly |
Thanks, trying now. Actually before checking out the assembly branch in your repository command "git branch" shows only the master branch. Should probably use "git branch -a" to see all. |
Confirm that the problem was fixed on ickby's branch. |
| 2013-09-24 16:09 | project4 | New Issue | |
| 2013-09-24 17:12 | ickby | Note Added: 0003648 | |
| 2013-09-24 18:35 | project4 | Note Added: 0003653 | |
| 2013-09-25 03:04 | ickby | Note Added: 0003656 | |
| 2013-09-25 03:54 | project4 | Note Added: 0003657 | |
| 2013-09-25 07:26 | project4 | Note Added: 0003658 | |
| 2013-09-25 10:13 | ickby | Note Added: 0003661 | |
| 2013-09-25 10:18 | ickby | Note Edited: 0003661 | |
| 2013-09-25 10:23 | ickby | Note Edited: 0003661 | |
| 2013-09-25 10:40 | project4 | Note Added: 0003662 | |
| 2013-09-25 13:33 | project4 | Note Added: 0003665 | |
| 2015-01-08 06:56 | jmaustpc | Status | new => closed |
| 2015-01-08 06:56 | jmaustpc | Assigned To | => jmaustpc |
| 2015-01-08 06:56 | jmaustpc | Resolution | open => fixed |
| 2015-01-08 06:56 | jmaustpc | Fixed in Version | => 0.14 |
