| 0001257 | FreeCAD | Bug | public | 2013-09-26 14:21 | 2014-03-02 12:13 |
| Reporter | pkoning | Assigned To | |||
| Summary | 0001257: Crash on fuse() of two simple extrusions | ||||
| Description | The attached test script reliably crashes FreeCAD. It seems to be related to the fact that the two shapes touch; if I move them apart, things work properly. | ||||
2013-09-26 14:21
The above script works for me. No crash! Two notes: If you plan to only translate or rotate a shape then never use transformGeometry() because it changes the underlying geometry -- usually to B-spline curves/surfaces. Use tramsformShape() instead It's a known problem (of the CAD kernel) that boolean operations often fail if faces only touch. |
I wonder if the fact I use transformGeometry is why my fuse operations are so slow. I tried transformShape, but for particular object I tried it on that produced an empty shape. What types of shapes will transformShape accept? It didn't seem to like wires. FWIW, my platform is a Mac, 10.8.4, 64 bit. |
Never mind, I see why I had trouble with transformShape. Inconsistent API: transformGeometry leaves "self" alone and returns a new object which is the transformed one, while transformShape changes the "self" object and returns None. The __doc__ strings are not at all clear about this. And yes, I tried that and it works, and my design builds a whole lot faster now. Thanks very much. |
git show 5f7ed33 clarifies the API |
| 2013-09-26 14:21 | pkoning | New Issue | |
| 2013-09-26 14:21 | pkoning | File Added: fusebug.py | |
| 2013-09-26 18:38 | wmayer | Note Added: 0003681 | |
| 2013-09-26 19:37 | pkoning | Note Added: 0003683 | |
| 2013-09-26 22:58 | pkoning | Note Added: 0003686 | |
| 2014-03-02 12:13 | wmayer | Note Added: 0004352 | |
| 2014-03-02 12:13 | wmayer | Status | new => closed |
| 2014-03-02 12:13 | wmayer | Resolution | open => fixed |
| 2014-03-02 12:13 | wmayer | Fixed in Version | => 0.14 |
