0001261SketcherFeaturepublic2014-03-11 01:51
Reportermntc Assigned To
PrioritynormalSeverityfeatureReproducibilityhave not tried
Summary0001261: Import raw sketch from webcam
DescriptionSometimes it is more convenient and fast to draw sketch by hand on paper. It is common step before engineer's brain is ready to think about dimensions and constraints. It would be fantastic if I could put paper under webcam and click some button to launch the next chain of actions:
1. Take photo image
2. Process it from raster to vector
3. Find contours, arcs, circles, lines and create corresponding geometry in sketch with some accuracy
Thus I will only have to adjust ready geometry.
yorik
2013-10-01 20:08
administrator   ~0003708
I'm afraid this is way out of FreeCAD's scope... You would e much better with vector-processing apps such as inkscape, which by the way can do that kind of job pretty well. You can then easily import the result in FreeCAD after cleaning.
mntc
2013-10-02 04:49
reporter   ~0003709
Yes, of course. I'm talking about calling external vector-processing application from FreeCAD without need to open, control and close it manually.
yorik
2014-03-11 01:51
administrator   ~0004413
I suppose we can close this...
2013-10-01 17:57 mntc New Issue
2013-10-01 20:08 yorik Note Added: 0003708
2013-10-02 04:49 mntc Note Added: 0003709
2014-03-11 01:51 yorik Note Added: 0004413
2014-03-11 01:51 yorik Status new => closed
2014-03-11 01:51 yorik Resolution open => won't fix
