| 0001269 | FreeCAD | Feature | public | 2013-10-10 21:18 | 2013-10-11 10:35 |
| Reporter | imyrek | Assigned To | wmayer | ||
| Priority | normal | Severity | minor | Reproducibility | random |
| Summary | 0001269: Parametr "tolerance" in "Create Mesh from geometry" work strange. | ||||
| Description | Parameter "tolerance" in python scripting Part.Shape.tessellate(tolerance) and in GUI menu "Mesh Design" -> "Meshes" -> "Create Mesh from geometry" work strange. Sometime it work correct, and sometime FreeCAD use previous value of this parametr(or return previous Mesh?). Tested on: OS: "Fedora release 18 (Spherical Cow)" Platform: 64-bit Version: 0.13.$WCREV$ Python version: 2.7.3 Qt version: 4.8.4 Coin version: 2.5.0 SoQt version: 1.5.0 OCC version: 6.5.4 OS: Ubuntu 10.04.4 LTS Platform: 32-bit Version: 0.14.2509 (Git) Branch: master Hash: 7cecafefaa67298486f6538ab34389dd825e38ae Python version: 2.6.5 Qt version: 4.6.2 Coin version: 3.1.2 SoQt version: 1.4.2a OCC version: 6.3.0 | ||||
| Additional Information | Python 2.7.3 (default, Aug 9 2012, 17:23:57) [GCC 4.7.1 20120720 (Red Hat 4.7.1-5)] on linux2 (...) >>> testPart = FreeCAD.ActiveDocument.addObject("Part::Feature","TestPart") >>> testPart.Shape=Part.makeSphere(66) >>> testPart.Shape.tessellate(6)[1].__len__() 2406 >>> testPart.Shape.tessellate(5)[1].__len__() 2406 >>> testPart.Shape.tessellate(4)[1].__len__() 2406 >>> testPart.Shape.tessellate(1)[1].__len__() 2406 >>> testPart.Shape.tessellate(0.6)[1].__len__() 2556 >>> testPart.Shape.tessellate(0.4)[1].__len__() 3830 >>> testPart.Shape.tessellate(0.2)[1].__len__() 6896 >>> testPart.Shape.tessellate(0.1)[1].__len__() 12962 >>> testPart.Shape.tessellate(0.06)[1].__len__() 20178 >>> testPart.Shape.tessellate(0.1)[1].__len__() 12962 >>> testPart.Shape.tessellate(0.2)[1].__len__() 12962 >>> testPart.Shape.tessellate(0.4)[1].__len__() 12962 >>> testPart.Shape.tessellate(0.6)[1].__len__() 12962 >>> testPart.Shape.tessellate(1)[1].__len__() 12962 >>> testPart.Shape.tessellate(0.66)[1].__len__() 12962 >>> testPart.Shape=Part.makeSphere(66) >>> testPart.Shape.tessellate(0.66)[1].__len__() 2406 >>> testPart.Shape.tessellate(1)[1].__len__() 2406 >>> testPart.Shape.tessellate(0.01)[1].__len__() 98036 >>> >>> testPart.Shape.tessellate(0.1)[1].__len__() 98036 >>> testPart.Shape.tessellate(1)[1].__len__() 98036 >>> | ||||
When tessellating a shape the mesh is kept internally because this is used for many algorithms like bounding box checks, boolean operations, ... If you tessellate a mesh with a certain tolerance then it overwrites the current mesh if it's finer (i.e. has more triangles). This means that if you again try to create a coarser mesh this will be rejected. So, this is totally comprehensible behaviour. |
There is now second but optional argument in tessellate(). False (default) means to keep the old triangulation amd True means to clear it. So, this snippet will show the behaviour you have expected: testPart = FreeCAD.ActiveDocument.addObject("Part::Feature","TestPart") testPart.Shape=Part.makeSphere(66) testPart.Shape.tessellate(6,True)[1].__len__() testPart.Shape.tessellate(5,True)[1].__len__() testPart.Shape.tessellate(4,True)[1].__len__() testPart.Shape.tessellate(1,True)[1].__len__() testPart.Shape.tessellate(0.6,True)[1].__len__() testPart.Shape.tessellate(0.4,True)[1].__len__() testPart.Shape.tessellate(0.2,True)[1].__len__() testPart.Shape.tessellate(0.1,True)[1].__len__() testPart.Shape.tessellate(0.06,True)[1].__len__() testPart.Shape.tessellate(0.1,True)[1].__len__() testPart.Shape.tessellate(0.2,True)[1].__len__() testPart.Shape.tessellate(0.4,True)[1].__len__() testPart.Shape.tessellate(0.6,True)[1].__len__() testPart.Shape.tessellate(1,True)[1].__len__() testPart.Shape.tessellate(0.66,True)[1].__len__() testPart.Shape=Part.makeSphere(66) testPart.Shape.tessellate(0.66,True)[1].__len__() testPart.Shape.tessellate(1,True)[1].__len__() testPart.Shape.tessellate(0.01,True)[1].__len__() testPart.Shape.tessellate(0.1,True)[1].__len__() testPart.Shape.tessellate(1,True)[1].__len__() |
git show e631be1 |
| 2013-10-10 21:18 | imyrek | New Issue | |
| 2013-10-11 10:15 | wmayer | Note Added: 0003728 | |
| 2013-10-11 10:32 | wmayer | Assigned To | => wmayer |
| 2013-10-11 10:32 | wmayer | Status | new => assigned |
| 2013-10-11 10:32 | wmayer | Category | Bug => Feature |
| 2013-10-11 10:34 | wmayer | Note Added: 0003729 | |
| 2013-10-11 10:35 | wmayer | Note Added: 0003730 | |
| 2013-10-11 10:35 | wmayer | Status | assigned => closed |
| 2013-10-11 10:35 | wmayer | Resolution | open => fixed |
| 2013-10-11 10:35 | wmayer | Fixed in Version | => 0.14 |
