0001283SketcherBugpublic2016-02-10 14:40
Reporterbejant Assigned Tojmaustpc
Product Version0.13
Summary0001283: Y and Z Sketch Planes not Exactly at Origin.
DescriptionWhen I create a new sketch, the default Y axis and Z axis sketch planes seem to be located a slight distance away from 0,0,0.
In FreeCAD Part Design workbench, select File -> New, then Tasks tab -> Create Sketch, in the Choose Orientation pop-up window accept the default Sketch Orientation of X-Y Plane by clicking the OK button. Create a simple Sketch and Pad it 10 units of your choice. Rotate the model to look at the bottom. Hover the cursor over the bottom to pre-select it. The coordinates display at the lower left of the screen shows the bottom face as being a few thousandths units away from the origin. Similarly the top face is 10 units plus the error away from the origin. Open the Edit Sketch window, hover over an item to preselect it, and the Z coordinate is the same number of units away from the origin.
I get a similar result when making a sketch in the X-Z plane, the Y axis location of the Sketch is not exactly at the origin.
When making a Sketch in the Y-Z Plane, the X axis location of the Sketch does seem to be exactly at the origin.
OS: Windows XP
Platform: 32-bit
Version: 0.14.2370 (Git)
Hash: a836759ebd91404954a778ff8885e152611576e1
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
Additional InformationForum thread:
http://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=3&t=4679&start=0
bejant
2013-11-02 22:29
reporter   ~0003849
After I filed this ticket I got a response in the forum explaining that this is intentional so as to make selecting points and vertices easier for the user; my apologies for the unnecessary ticket.
jmaustpc
2016-02-10 14:40
manager   ~0006819
Hi Bejant
Looks like no one closed this old ticket that you said was resolved a long time ago. I just tried it FreeCAD 0.16dev and can not reproduce it. I will close this then, of course let me know and I would reopen it if needed.
2013-10-19 19:05 bejant New Issue
2013-11-02 22:29 bejant Note Added: 0003849
2016-02-10 14:40 jmaustpc Note Added: 0006819
2016-02-10 14:40 jmaustpc Status new => closed
2016-02-10 14:40 jmaustpc Assigned To => jmaustpc
2016-02-10 14:40 jmaustpc Resolution open => no change required
