| 0001295 | Draft | Bug | public | 2013-11-02 16:48 | 2014-05-03 15:44 |
| Reporter | raulshc | Assigned To | yorik | ||
| Summary | 0001295: Snap cursors are not shown when there is an active command | ||||
| Description | Draft cursor neither any of draft snap cursors are shown when one performs a command. See the example screenshot, when line command and midpoint snap are actived. Snapmarker are not affected. I tested it on WinXP SP3 only. May be the typical Qt/SVG/WinXP endless problem. | ||||
| Additional Information | OS: Windows XP Platform: 32-bit Version: 0.14.2370 (Git) Branch: master Hash: a836759ebd91404954a778ff8885e152611576e1 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 | ||||
The issue is reproduced in 0.13 stable release too. |
Oops I hadn't seen this. Is this bug still happening? Any error message appearing on the python console? |
Yes, the report view yields the following: pycollada not found, collada support will be disabled. Draft workbench activated Pick first point: Pick next point: Pick first point: Pick next point: Pick first point: Pick next point: <type 'exceptions.KeyError'> <type 'exceptions.KeyError'> <type 'exceptions.KeyError'> ... more times The python console shows: Python 2.6.2 (r262:71600, Jun 22 2009, 21:44:05) [MSC v.1500 32 bit (Intel)] on win32 Type 'help', 'copyright', 'credits' or 'license' for more information. >>> App.newDocument() >>> App.setActiveDocument("Unnamed") >>> App.ActiveDocument=App.getDocument("Unnamed") >>> Gui.ActiveDocument=Gui.getDocument("Unnamed") >>> import Draft >>> points=[FreeCAD.Vector(-2.11421513557,0.726311922073,0.0),FreeCAD.Vector(7.25220966339,-4.24185800552,0.0)] >>> Draft.makeWire(points,closed=False,face=False,support=None) >>> App.getDocument("Unnamed").removeObject("Line") >>> import Draft >>> points=[FreeCAD.Vector(-212.378845215,108.159111023,0.0),FreeCAD.Vector(248.005142212,-142.533432007,0.0)] >>> Draft.makeWire(points,closed=False,face=False,support=None) |
It's hard to know what is happening, there is no error message... Can you try this in the python window (you must have a document open): import DraftGui from PyQt4 import QtGui print DraftGui.getMainWindow().findChildren(QtGui.QWidget,"QtGLArea") and paste here any resulting message? Thanks |
Document of draft entities opened. Answer is the null array [] >>> import DraftGui >>> from PyQt4 import QtGui >>> print DraftGui.getMainWindow().findChildren(QtGui.QWidget,"QtGLArea") [] >>> No report view messages. |
Okay... It doesn't find the 3D view, therefore it doesn't set its cursor. Probably something in Qt that behaves differently on your system. I'll try to find a workaround. |
The following topic on the forum may be related with this issue: http://forum.freecadweb.org/viewtopic.php?f=10&t=4613 |
The author of the forum post solved the problem by deleting his .FreeCAD folder. Can you try that too? *EDIT* Sorry, on windows it is different... Iis the FreeCAD user folder, which must be located in C:/Users/youruser/Application Data/FreeCAD or something similar... |
That's correct, is located on C:/Users/youruser/Application Data/. I tried this when I readed the post, but didn't work. Snap and snapmarkers work but the draft cursor neither any of draft snap cursors are shown. Humm, I suspect it may be a bug in the Qt version 4.5.2, I tried with 4.8.1 but FreeCAD crashes so one could not check. Yorik, change the status of this issue to feedback, I will try to compile the latest source code from git and will test it with recent qt binaries (>=4.8.0) during this month. I will test it with other windows version more modern too. I'll tell you how it goes. |
Great! Thanks a lot for investigating this further... And indeed it is very likely, ther eis a number of bugs between Qt versions... |
I have tested it and it works as expected on: OS: Windows 7 Platform: 32-bit Version: 0.14.3390 (Git) Branch: master Hash: b5b6d49d2e7c0f3fefef3e368cb0b9edd043d757 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 |
Ok, thanks a lot for testing! I'll leave this open a bit more to see if no more reports comes... Unfortunately in the case of windowsXP (as the OP reported), since it's being abandoned by microsoft, there will likely be more and more unfixable bugs on that platform... |
I have tested my built today on win XP. It works here too. |
I'll close this bug report since it seems things are solved. Reopen if needed! |
| 2013-11-02 16:48 | raulshc | New Issue | |
| 2013-11-02 16:48 | raulshc | File Added: snap_cursors.png | |
| 2013-11-02 16:51 | raulshc | Note Added: 0003848 | |
| 2013-11-04 12:48 | yorik | File Deleted: snap_cursors.png | |
| 2013-11-04 12:48 | yorik | File Added: snap_cursors.png | |
| 2013-11-20 19:28 | yorik | Assigned To | => yorik |
| 2013-11-20 19:28 | yorik | Status | new => assigned |
| 2013-11-20 19:29 | yorik | Note Added: 0003896 | |
| 2013-11-20 19:29 | yorik | Status | assigned => feedback |
| 2013-11-21 17:53 | raulshc | Note Added: 0003898 | |
| 2013-11-21 17:53 | raulshc | Status | feedback => assigned |
| 2013-12-22 19:45 | yorik | Note Added: 0003964 | |
| 2013-12-22 19:53 | yorik | Status | assigned => feedback |
| 2013-12-23 00:33 | raulshc | Note Added: 0003968 | |
| 2013-12-23 00:33 | raulshc | Status | feedback => assigned |
| 2013-12-23 01:16 | yorik | Note Added: 0003969 | |
| 2013-12-25 17:57 | raulshc | Note Added: 0003981 | |
| 2014-01-01 15:30 | yorik | Note Added: 0003993 | |
| 2014-01-01 15:31 | yorik | Note Edited: 0003993 | |
| 2014-01-03 23:32 | raulshc | Note Added: 0004020 | |
| 2014-01-03 23:48 | yorik | Note Added: 0004021 | |
| 2014-01-03 23:49 | yorik | Status | assigned => feedback |
| 2014-02-23 20:47 | yorik | Relationship added | related to 0001433 |
| 2014-04-06 12:16 | microelly2 | Note Added: 0004533 | |
| 2014-04-06 16:13 | yorik | Note Added: 0004534 | |
| 2014-04-07 10:06 | microelly2 | Note Added: 0004537 | |
| 2014-05-03 15:44 | yorik | Note Added: 0004608 | |
| 2014-05-03 15:44 | yorik | Status | feedback => closed |
| 2014-05-03 15:44 | yorik | Resolution | open => no change required |
| 2014-05-03 15:44 | yorik | Fixed in Version | => 0.14 |
