0001299FreeCADFeaturepublic2013-11-09 16:54
Reporternikospap Assigned Towmayer
PlatformLinuxOSMageia LinuxOS Version3
Product Version0.12
Summary0001299: dis-place/move objects at an angle (not rotate)
DescriptionEither Freecad doesn't have this feature, or I couldn't figure it out.
I want to be able to create an object,
and then place it (move it) at a certain distance,
but not left-right, up or down,
but at a certain angle.
Steps To ReproduceExample (see following pictures):
I want to create a circle (cylinder), placed in the center.
Then duplicate it.
Then move that duplicate 20mm farther,
at an angle of 60 degrees,
in relation to the north.
In the example, we are at the YX plane.
Where the Y arrow points, I name it North (0 degrees).
Then create another duplicate of the original circle,
and place it 20mm away,
when measuring at -60 degrees.
And then create a third copy of the original circle,
and place at 180 degrees, 20mm from the original place.
The third picture shows what I want to create.
nikospap
2013-11-07 23:09
reporter
nikospap
2013-11-07 23:09
reporter
nikospap
2013-11-07 23:09
reporter
2013-11-08 15:42
administrator
0001299.fcstd (Attachment missing)
2013-11-08 15:44
administrator   ~0003871
If your version is really 0.12 then you should update to 0.13 or even get the development version.
I don't remember how advanced the sketcher module was in 0.12 but that's one way to go. Attached is a file how it can be done.
Maybe it would be better to first discuss things in the forum if you are unsure.
nikospap
2013-11-09 07:08
reporter   ~0003872
I had tried with version 0.13, under Wine
(in Linux; no 0.13 version for Mageia),
but still couldn't find the way.
So I see... you can use Sketcher,
create some additional lines, necessary for angle constraints,
and then toggle them out of construction mode.
Different way of thinking, than mine, of "moving things around in 3D".
Thanks...
and sorry for the trouble.
2013-11-09 08:53
administrator   ~0003873
Yes, for this specific case you described this is an alternative way of doing it.
A further alternative is to create only the "northern" circle and then use the polar array from the Draft module. This is useful if your original shape is a bit more complex than a simple circle. The good thing with the polar array is that it automatically makes objects symmetric with respect to a given center point. This means you don't have to deal with the distances and the angles. Everything is done automatically.
Ah no problem. Do you think this feature request can be closed, then?
2013-11-09 09:00
administrator   ~0003874
And there is even a third way of doing it. The again only uses sketcher commands but requires 0.13 again. The steps:
1. Create the big circle first and pad it.
2a. Create a new sketch choosing the top plane of the pad
2b. Make the "northern" circle and pocket it.
3. Select the pocket and use the polar pattern feature and choose 3 as the number of elements
4a. Create a new sketch choosing the top plane
4b. Create the inner circle and pocket it
I guess this is the most direct way of doing it.
nikospap
2013-11-09 15:47
reporter   ~0003875
Just checked the two other ways you suggested.
The third way seems to be the "cleanest".
Yeap.
2013-11-07 23:06 nikospap New Issue
2013-11-07 23:09 nikospap File Added: place-move_at_an_angle_011b.jpg
2013-11-07 23:09 nikospap File Added: place-move_at_an_angle_012b.jpg
2013-11-07 23:09 nikospap File Added: place-move_at_an_angle_004.png
2013-11-08 15:42 wmayer File Added: 0001299.fcstd
2013-11-08 15:44 wmayer Note Added: 0003871
2013-11-09 07:08 nikospap Note Added: 0003872
2013-11-09 08:53 wmayer Note Added: 0003873
2013-11-09 09:00 wmayer Note Added: 0003874
2013-11-09 15:47 nikospap Note Added: 0003875
2013-11-09 16:54 wmayer Status new => closed
2013-11-09 16:54 wmayer Assigned To => wmayer
2013-11-09 16:54 wmayer Resolution open => no change required
