| 0000130 | FreeCAD | Bug | public | 2010-08-04 15:18 | 2011-01-06 21:20 |
| Priority | normal | Severity | major | Reproducibility | random |
| Target Version | 0.11 | ||||
| Summary | 0000130: Bugs and issues in sketcher | ||||
| Description | For me the sketcher crashes quite often but the problem is not reproducible. But it almost happens when leaving the edit mode inside ViewProviderSketch::unsetEdit() at the line EditRoot->removeAllChildren(). The stack trace reports about a heap corruption deep inside one of the SoMaterial nodes in the diffuseColor field. Since there is no double deletion of a wild pointer in the ViewProviderSketch class or an error with reference counting there must something happen with the diffuseColor field at runtime. Today I realized a possible problem in the method createEditInventorNodes(): For the last line set EditCurvesMaterials there is defined an own SoMaterial node but not a new SoMaterialBinding for it. The behavior then is that the material binding of CurvesMaterials above is used which is set to PER_FACE. Since EditCurvesMaterials doesn't set more than one color the binding of PER_FACE is of course wrong. I think there must be added a further material binding node which is set to OVERALL. A second strange behavior is when dragging points and moving them. If you have a polyline and drag vertex XY then edge XY is highlighted during the movement. | ||||
I found the error of the funny behavior with the colors. Inside the method ViewProviderSketch::draw(bool) there are the lines: if (PreselectPoint >= 0 && PreselectPoint < (int) Points.size()) color[PreselectPoint]=PreselectColor; which is definitely wrong because it ses the color of the lines. This very likely also responsible for the crash. The lines must be: if (PreselectPoint >= 0 && PreselectPoint < (int) Points.size()) pcolor[PreselectPoint]=PreselectColor; I have already checked-in the fix. There is also another bug I encountered. If you create a polyline and move very fast, click to create a point but do not stop moving and click again you'll produce two lines which are disconnected. |
I experienced the same crashes (seldom but steady) and located it to the unsetEdit() methode, when all children of the EditRoot get deleted.. But maybe you fixed it already with pcolor (which has the potential to overwrite the stack...). I will look into the polyline! |
Another thing I noticed with the polyline command. It would be good if it could create a wire instead of a compound because otherwise commands like padding don't work. |
Yupp, at the moment I do it the lazy way by fuse(), which create a compound!?? Its in: Sketcher::Sketch::toShape() At the end what I would like to do is create with the geos and the constraints the vertexes and edges one by one, to ensure the the same position after a change. Which is very important for later linking to faces or edges. |
The crash after edit has vanished after you fix. The same for you? |
I'm not sure. When leaving edit mode I don't have a crash anymore but right now it crashed when moving one of the vertices directly after picking. It's good possible that this results from a further bug. |
To the compound: Yes, the boolean fuse produces compounds but for a polyline it's just a container with a single wire inside. Since for a general sketch there can be several wires or free edges inside the compound one can count the wires, count the edges and if there is only one wire count the edges of this wire. So, if there is only one wire and number of edges in the wire is equal to the number of edges inside the compound we can be sure that there is exactly one wire inside and nothing else. > At the end what I would like to do is create with the geos and the constraints > the vertexes and edges one by one, to ensure the the same position after > a change. Which is very important for later linking to faces or edges. I'm not sure if the fuse() can guarantee this. At least if it's allowed to insert a line afterwards somewhere I guess the fuse() will fail. Maybe this algorithm can be useful for you: void connectEdges (const std::list<TopoDS_Edge>& edges, std::list<TopoDS_Wire>& wires) const { std::list<TopoDS_Edge> edge_list = edges; while (edge_list.size() > 0) { BRepBuilderAPI_MakeWire mkWire; // add and erase first edge mkWire.Add(edge_list.front()); edge_list.erase(edge_list.begin()); TopoDS_Wire new_wire = mkWire.Wire(); // current new wire // try to connect each edge to the wire, the wire is complete if no more egdes are connectible bool found = false; do { found = false; for (std::list<TopoDS_Edge>::iterator pE = edge_list.begin(); pE != edge_list.end();++pE) { mkWire.Add(*pE); if (mkWire.Error() != BRepBuilderAPI_DisconnectedWire) { // edge added ==> remove it from list found = true; edge_list.erase(pE); new_wire = mkWire.Wire(); break; } } } while (found); wires.push_back(new_wire); } } |
delivers now wires, but have still an issue with closing a polyline not at the beginning.... |
Sketcher crashes when forcing with the Close button in the task panel to exit edit mode and reenter edit mode if the last operation wasn't completed. This is because no SketchHandler instance is created anymore. BTW, it seems there is also a memory leak when leaving edit mode because the sketch handler instance isn't destroyed. |
This are a very unspecific error report. Close this in favour for new ones which are more specific.... |
| 2010-08-04 15:18 | wmayer | New Issue | |
| 2010-08-04 15:18 | wmayer | Status | new => assigned |
| 2010-08-04 15:18 | wmayer | Assigned To | => Jriegel |
| 2010-08-04 17:41 | wmayer | Note Added: 0000284 | |
| 2010-08-04 19:48 |
Note Added: 0000285 | |
| 2010-08-05 06:56 | wmayer | Note Added: 0000287 | |
| 2010-08-05 12:58 |
Note Added: 0000288 | |
| 2010-08-05 14:05 |
Note Added: 0000289 | |
| 2010-08-06 05:48 | wmayer | Note Added: 0000290 | |
| 2010-08-06 06:04 | wmayer | Note Added: 0000291 | |
| 2010-08-07 07:23 |
Note Added: 0000292 | |
| 2010-08-30 12:56 | wmayer | Note Added: 0000310 | |
| 2011-01-06 21:20 |
Note Added: 0000485 | |
| 2011-01-06 21:20 |
Status | assigned => closed |
| 2011-01-06 21:20 |
Resolution | open => fixed |
