| 0001300 | File formats | Feature | public | 2013-11-08 11:33 | 2016-01-31 18:42 |
| Reporter | ch.buehler | Assigned To | yorik | ||
| Platform | Arch Linux | ||||
| Summary | 0001300: Importing OBJ does not load Material | ||||
| Description | When I try to open a .obj file, the geometry loads fine, but colorless. The importer seems to ignore the associated .mtl file. | ||||
> The importer seems to ignore the associated .mtl file. Does this mean that colours are not part of the obj file but offered by a separate file? Sounds weird! Can you offer a simple example, please? |
For an example see http://people.cs.clemson.edu/~dhouse/courses/405/docs/brief-obj-file-format.html (Cube with Materials) |
I am also bumping into this missing feature on: OS: Windows 7 Platform: 32-bit Version: 0.13.1828 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.3.0 I uploaded (hope so) and example (blue-plastic-push-buttons.obj and .mtl). Place those 2 files in the same directory. Open the .obj file with GLC player and you should see a blue part. Open this same .obj file with FreeCAD and you should see a gray part. François |
closing this as it is being handled by 0002139 |
| 2013-11-08 11:33 | ch.buehler | New Issue | |
| 2013-11-08 15:27 | wmayer | Note Added: 0003869 | |
| 2013-11-08 15:43 | ch.buehler | Note Added: 0003870 | |
| 2013-11-08 17:56 | wmayer | Category | => Feature |
| 2013-11-14 20:29 | donze | File Added: blue-plastic-push-buttons.obj | |
| 2013-11-14 20:30 | donze | File Added: blue-plastic-push-buttons.mtl | |
| 2013-11-14 20:35 | donze | Note Added: 0003883 | |
| 2013-11-20 19:19 | yorik | Severity | major => minor |
| 2015-09-09 22:02 | savio araujo | Issue cloned: 0002256 | |
| 2015-09-10 19:10 | yorik | Relationship added | has duplicate 0002256 |
| 2016-01-31 18:41 | yorik | Relationship added | duplicate of 0002139 |
| 2016-01-31 18:41 | yorik | Note Added: 0006784 | |
| 2016-01-31 18:42 | yorik | Status | new => closed |
| 2016-01-31 18:42 | yorik | Assigned To | => yorik |
| 2016-01-31 18:42 | yorik | Resolution | open => duplicate |
