| 0001311 | FreeCAD | Bug | public | 2013-11-17 20:18 | 2013-11-18 11:22 |
| Reporter | quick61 | Assigned To | yorik | ||
| Priority | low | Severity | crash | Reproducibility | always |
| Platform | Linux | OS | Linux | OS Version | Kubuntu 13.10 64 |
| Summary | 0001311: Draft-Upgrade of Cross-sections tool causes abort crash when slicing Cylinder, Cone, Sphere, Torus, and other rounded shapes | ||||
| Description | When attempting to upgrade a Cross-Sections slice of a Cylinder, Cone, Sphere, Torus, and other rounded shapes to a face. Application of the upgrade tool in the Draft Workbench brings on an abort/crash. This happens 100% of the time *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0 OS: Ubuntu 13.10 Platform: 64-bit Version: 0.14.2755 (Git) Branch: master Hash: 7651593ca352cb00b513d96d9585db4d4a9428ad Python version: 2.7.5+ Qt version: 4.8.4 Coin version: 4.0.0a SoQt version: 1.5.0 OCC version: 6.5.4 | ||||
| Steps To Reproduce | Open Part Workbench. Create a Cylinder. Select Cylinder and invoke Cross-sections tool. Leave Defaults and click OK. Open Draft Workbench. Select Cylinder_cs and invoke Upgrade tool. Crash / Abort | ||||
| Additional Information | This does not happen with squared corner parts constructed from sketches or the Solid Box from the Part Workbench. Seems to be limited to Cross-scetions taken from rounded shapes. | ||||
It doesn't crash for me with any of these combinations... But I'm with OCC 6.6 (OCE13), it might be a problem that they solved... Let's see if anyone else is experiencing a crash there. |
Not crashing for me. oce13 also. |
You are correct yorik, I just compiled the latest OEC and FreeCAD and all is well now. No more crashing. So it does seem that the problem was with the 0.12 OEC. OS: Ubuntu 13.10 Platform: 64-bit Version: 0.14.2758 (Git) Branch: master Hash: bcb7d02c05ffe842e2d8a5c1d08eb6058b2ab6de Python version: 2.7.5+ Qt version: 4.8.4 Coin version: 4.0.0a SoQt version: 1.5.0 OCC version: 6.6.0 |
Great then, let's close this. The best bugs are those you don't need to do anything about ;) |
| 2013-11-17 20:18 | quick61 | New Issue | |
| 2013-11-17 21:04 | yorik | Note Added: 0003891 | |
| 2013-11-17 21:04 | yorik | Assigned To | => yorik |
| 2013-11-17 21:04 | yorik | Status | new => assigned |
| 2013-11-17 21:04 | yorik | Status | assigned => feedback |
| 2013-11-17 23:34 | tanderson69 | Note Added: 0003892 | |
| 2013-11-18 02:34 | quick61 | Note Added: 0003893 | |
| 2013-11-18 02:34 | quick61 | Status | feedback => assigned |
| 2013-11-18 11:22 | yorik | Note Added: 0003894 | |
| 2013-11-18 11:22 | yorik | Status | assigned => closed |
| 2013-11-18 11:22 | yorik | Resolution | open => no change required |
| 2013-11-18 11:22 | yorik | Fixed in Version | => 0.14 |
