| 0001322 | FreeCAD | Bug | public | 2013-12-02 00:18 | 2015-12-15 13:18 |
| Reporter | dem0nax | Assigned To | wmayer | ||
| Platform | i386 - GNU LINUX | OS | Debian | OS Version | 7.2 |
| Product Version | 0.9 | ||||
| Summary | 0001322: Multple python versions in debian causing Python 2.6 (earlier Python version) linking and failing to install FreeCAD | ||||
| Description | Make produces multiple warnings and errors referencing pivy and other modules. Excerpts from the make std output are attached. | ||||
| Steps To Reproduce | # With python2.6 and python2.7 installed; # in freecad_build directory: cmake ../source_directory make | ||||
| Additional Information | Requested help at debian IRC: otfc.net, channel: #debian. IRC user ID: **themill** recommended forcing cmake to compile against python 2.7. After briefly perusing the docs on cmake, I modified the file: ../FreeCAD_sf_master/CMakeLists.txt. I changed the following line *from:* `set(Python_ADDITIONAL_VERSIONS "2.3" "2.4" "2.5" "2.6" "2.7" "2.8" "2.9")` *to:* `set(Python_ADDITIONAL_VERSIONS "2.7" "2.8" "2.9")` Then, FreeCAD compiled; I completed the basic tutorial, and it worked well. I suppose I may have changed the order to" "2.9" "2.8" "2.7" "2.6" versus the elimination process that I implemented. I'll eventually try that and report back. | ||||
I'm not sure this is something we should modify on the freecad side. Setting one version as default instead of another one could solve your problem on debian but create problems on another distro. On my debian system, the default python version is 2.7, and freecad compiles correctly with 2.7. And I have 2.6 installed too. Probably your default is 2.6 (the one that opens when you type "python") Maybe you need to change what your default python version is? Not sure how to do that, though. |
Usually /usr/bin/python is a symbolic which e.g. links to /usr/bin/python2.6. So, to change the default python version simply delete the symbolic link and create a new one to the desired python version. Nevertheless, I think there is a problem with the cmake test for python. In the past I didn't know of problems like this but in the last 0000010:0000012 months we had a couple of reports where the headers of python 2.x were used but the linker tried to link python 2.y and failed. |
Yorik, wmayer: Thank you for your response. Python 2.7 was default when I compiled FreeCAD and still is. Excerpt from `ls -halt` output on /usr/bin: lrwxrwxrwx 1 root root 9 Sep 28 15:41 python -> python2.7 lrwxrwxrwx 1 root root 9 Sep 28 15:41 python2 -> python2.7 lrwxrwxrwx 1 root root 16 Sep 28 15:41 python-config -> python2.7-config I understand that changes accommodating one OS may damage another. I generated this report to offer a possible work-around solution to those that happen to find it. stuart@themill.user.oftc.net reported on IRC: "are you compiling against python 2.6 or 2.7 there? (can you force it to only compile against python 2.7? apparently the freecad build system has a nasty habit of doing the wrong thing here)" As you mentioned, this indicates that multiple people/systems are experiencing this issue. |
I have the problem too. So my workaround is to edit the cmakecache.txt file and replace all python2.6 items with python2.7. After that you can call again cmake . and everything is fine. The interesting thing is, there are some places where python2.7 is put in from the beginning. So I have a mix of python2.6 and python2.7 in the cmakecache.txt after the first call of cmake-gui. |
Can you try setting the CMAKE Variable -DPYTHON_EXECUTABLE:FILEPATH=/usr/bin/python2 Seemed to work fine for me using python 2.7 on Arch |
| 2013-12-02 00:18 | dem0nax | New Issue | |
| 2013-12-02 00:18 | dem0nax | File Added: make_excerpts.log | |
| 2013-12-02 13:30 | yorik | Note Added: 0003915 | |
| 2013-12-02 14:23 | wmayer | Note Added: 0003918 | |
| 2013-12-03 01:17 | dem0nax | Note Added: 0003920 | |
| 2014-01-23 21:57 | ulrich1a | Note Added: 0004117 | |
| 2014-02-08 00:30 | mrlukeparry | Note Added: 0004163 | |
| 2015-07-30 22:37 | wmayer | Changeset attached | => FreeCAD Master master 8da4f1dd |
| 2015-07-30 22:37 | wmayer | Assigned To | => wmayer |
| 2015-07-30 22:37 | wmayer | Status | new => closed |
| 2015-07-30 22:37 | wmayer | Resolution | open => fixed |
