| 0001326 | FreeCAD | Bug | public | 2013-12-07 03:18 | 2014-03-04 11:33 |
| Reporter | Epartsman | Assigned To | wmayer | ||
| Platform | x86 | OS | Ubuntu | OS Version | LTS 12.04 |
| Summary | 0001326: Starting FreeCAD Produces Blank Window with Granite Texture | ||||
| Description | Installed FreeCAD from both Ubuntu Software Center as well as command line. In both cases, I get a splash screen with some quickly changing text. Then the main window opens and all I have is the borders, a large area that looks like granite, and a "Report View" pane at the bottom. Menu options available are File>Exit, Edit>Preferences, View>Workbench> (A whole list here), Help>Help,About and About Qt. | ||||
| Steps To Reproduce | Start FreeCAD | ||||
| Additional Information | Screenshot Attached. | ||||
> View>Workbench> (A whole list here) Does it work to switch to one of them? |
v0.12 is not really maintained by the FreeCAD team. It is really old! Why don't you add one of the two PPA from the FreeCAD project, to update FreeCAD to the latest version... Relevant info is in the wiki. |
Starting installed FreeCAD from terminal window: cbe@b9Lap:~$ freecad FreeCAD 0.14, Libs: 0.14R2800 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 I don't know if this is relevant, but this is my experience of a rather fresh software version: First of all I get a little confused by the versioning numbers regarding installed debs which is version 0.14R2800 (Git) Help dialog window tells me also that this is the "Branch master". (Taken from a Ubuntu PPA) When I do git pull from sourceforge.sf master branch it is indicating version 0.13 and a much lower version number. Am I taking the daily git source pull from wrong repository?? (The cmake/make will not run and is reported separate) =============== I run Debian Sid Amd64 (Unstable) Tried to install FreeCAD as a deb package. (The version 014R2800 as shown above) After initial startup I get only the main menu, and a grey workarea. I select the Sketcher workbench -> File new ->new sketch icon and get the blue workarea and coordinate crosshairs shown on the screen work area. When I try to make a line with the linetool nothing happens, and I get following error in the terminal window: Coin warning in SbDPViewVolume::getMatrices(): invalid frustum Coin warning in SbDPLine::setValue(): The two points defining the line is equal => line is invalid. Coin warning in SbDPViewVolume::getMatrices(): invalid frustum Coin warning in SbDPLine::setValue(): The two points defining the line is equal => line is invalid. In Part design workbbench trying to make a line I get following error: Unhandled exception in ViewProvider::eventCallback: Both points are equal Unhandled exception in ViewProvider::eventCallback: Both points are equal In Draft workbench: I can make line and polyline without any problem. But have in mind that my Debian Sid OS software is unstable version, and the FreeCAD (Ubuntu)package may be incompatible with my Debian version, even though it installed without any shown error. This is my versions which differ from what's stated in the wiki: ii libcoin80 3.1.4~abc9f50-4 amd64 ii libcoin80-dev 3.1.4~abc9f50-4 amd64 ii libcoin80-doc 3.1.4~abc9f50-4 all ii libfreetype6:amd64 2.5.1-2 amd64 FreeType 2 font engine This for your information, and hopefully helpful. |
Coin warning in SbDPViewVolume::getMatrices(): invalid frustum Coin warning in SbDPLine::setValue(): The two points defining the line is equal => line is invalid. Coin warning in SbDPViewVolume::getMatrices(): invalid frustum Coin warning in SbDPLine::setValue(): The two points defining the line is equal => line is invalid. Unfortunately, there is a regression on the latest SoQt version which always set the near and far clipping plane to weird values if the 3d view is empty. This invalidates the frustum of the camera and thus commands like line creation don't work properly any more. Last week I have implemented a fix avoiding to invalidate the frustum. So, you should get the latest version from master and try again. |
Can you put the fix into 0.13? I think we should not patch 0.12. Too old... |
> Can you put the fix into 0.13? That's probably not needed as only SoQt 1.6 is affected by this regression and version 1.5 doesn't have this change. So, it's currently only relevant for Debian unstable/testing but I think 0.14 will be out soon... |
Here the link btw: https://bitbucket.org/Coin3D/sogui/diff/viewers/SoGuiViewer.cpp.in?diff2=239bd7ae533d&at=default |
I consider this fixed. |
| 2013-12-07 03:18 | Epartsman | New Issue | |
| 2013-12-07 03:18 | Epartsman | File Added: Screenshot from 2013-12-06 22:17:15.png | |
| 2013-12-07 11:24 | wmayer | Note Added: 0003927 | |
| 2013-12-18 03:59 | normandc | Note Added: 0003945 | |
| 2013-12-19 02:15 | beckcb | Note Added: 0003949 | |
| 2013-12-19 02:23 | beckcb | Note Edited: 0003949 | |
| 2013-12-19 02:28 | beckcb | Note Edited: 0003949 | |
| 2013-12-19 09:26 | wmayer | Note Added: 0003950 | |
| 2013-12-23 07:23 |
Note Added: 0003971 | |
| 2013-12-23 07:24 |
| 2013-12-23 17:52 | wmayer | Note Added: 0003977 | |
| 2013-12-23 17:52 | wmayer | Note Added: 0003978 | |
| 2014-03-04 11:33 | wmayer | Note Added: 0004379 | |
| 2014-03-04 11:33 | wmayer | Status | acknowledged => closed |
| 2014-03-04 11:33 | wmayer | Assigned To | => wmayer |
| 2014-03-04 11:33 | wmayer | Resolution | open => fixed |
| 2014-03-04 11:33 | wmayer | Fixed in Version | => 0.14 |
