| 0001331 | FreeCAD | Bug | public | 2013-12-16 02:50 | 2015-01-06 23:19 |
| Reporter | angusjnorth | Assigned To | |||
| Platform | 32-bit | OS | Windows XP | ||
| Summary | 0001331: Cannot cut in 2D, then extrude resulting shape, then cut using that shape in 3D | ||||
| Description | Hi I am using FreeCAD for semiconductor process modelling. That involves making complex shapes (masks) in 2D, with Boolean operations, mostly cut. Then we extrude those shapes in 3D, then cut from another 3D shape to represent an etch process. This doesn't work - I get Traceback (most recent call last): File "<input>", line 1, in <module> Exception: BRep_API: command not done It works if I do all the cuts in 3D after extruding the individual polygons first, but that doesn't accurately represent the physical process I'm simulating and that makes the code far less readable. | ||||
| Steps To Reproduce | import Draft import FreeCAD r1=Draft.makeRectangle(27.75,52.475,FreeCAD.Placement(FreeCAD.Vector(-13.875,-45.2875,7),FreeCAD.Rotation(0,0,0,1))) r2=Draft.makeRectangle(12.75,4,FreeCAD.Placement(FreeCAD.Vector(-6.375,-13.2875,7),FreeCAD.Rotation(0,0,0,1))) cm = r1.Shape.cut(r2.Shape).extrude(Base.Vector(0,0,-6)) sol=Part.makeSolid(Part.makeBox(31.75, 63.5, 6, Base.Vector(15.875,-51.51257, 7), Base.Vector(0, 0, -1))) sol.cut(cm) Traceback (most recent call last): File "<input>", line 1, in <module> Exception: BRep_API: command not done | ||||
This is NOT happening here. Freecad sha 1333cb87348c8a9 OCE 0.14.1 Are you sure that the solids you are sending to the failing cut are what you expect? This workflow seems very unusual. |
Fails here (OCC vs OCE?): OS: Ubuntu 12.04.3 LTS Platform: 64-bit Version: 0.14.2849 (Git) Branch: SSPrefPatch Hash: 70946758451ddeeceb9520380bab29777e2a8a49 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.1 |
OCC doesn't like 2D Boolean ops very much. If the contours aren't too complicated, you can make your Face with a list of Wires instead. See pcb.py |
> Are you sure that the solids you are sending to the failing cut are what you expect? Yes, the 2D shapes are fine. > This workflow seems very unusual. It makes sense in the semiconductor processing context. Masks are 2D, but after etching, deposition etc., 3D shapes are created (from extruded 2D shapes). To make up the 2D shapes I was fusing together a bunch of 2D rectangles, which as wandererfan suggests may be triggering the bug. I worked around this problem by doing all my Boolean operations in 3D (no Booleans on 2D objects), and that works so I'm not that fussed about this bug now. My code is now: def CHAMBERmask(self, zPlacement, thickness): r1=Draft.makeRectangle(self.CHAMBERWIDTH,self.CHAMBERLENGTH,FreeCAD.Placement(FreeCAD.Vector(self.CHAMBERx,self.CHAMBERy,zPlacement),FreeCAD.Rotation(0,0,0,1))) r2=Draft.makeRectangle(self.BAFFLELENGTH,self.WALLTHICKNESS,FreeCAD.Placement(FreeCAD.Vector(self.BAFFLEx,self.BAFFLEy,zPlacement),FreeCAD.Rotation(0,0,0,1))) CHAMBERmask = r1.Shape.extrude(FreeCAD.Vector(0,0,-thickness)).cut(r2.Shape.extrude(FreeCAD.Vector(0,0,-thickness))) self.clearRectangles() return CHAMBERmask # this is now 3D, not 2D, so further booleans using this mask are ok Thanks Angus |
Thanks for pcb.py wandererfan - maybe I'll use that method instead. I see I had a spurious Part.makeSolid in my code too. |
| 2013-12-16 02:50 | angusjnorth | New Issue | |
| 2013-12-16 15:03 | tanderson69 | Note Added: 0003939 | |
| 2013-12-18 00:13 | wandererfan | Note Added: 0003940 | |
| 2013-12-18 00:16 | wandererfan | Note Added: 0003941 | |
| 2013-12-18 00:16 | wandererfan | File Added: pcb.py | |
| 2013-12-18 02:57 | angusjnorth | Note Added: 0003942 | |
| 2013-12-18 03:07 | angusjnorth | Note Added: 0003943 | |
| 2013-12-18 03:15 | angusjnorth | Note Edited: 0003942 | |
| 2015-01-06 23:19 | wmayer | Status | new => closed |
| 2015-01-06 23:19 | wmayer | Resolution | open => unable to reproduce |
