| 0001334 | FreeCAD | Bug | public | 2013-12-18 18:49 | 2014-01-02 12:57 |
| Reporter | mistria | Assigned To | wmayer | ||
| Summary | 0001334: Applying extrude does not close the task | ||||
| Description | When I want to extrude and click "Apply" no feedback is given and the task is still active. That makes me believe the extrude operation failed so I reclick on "apply". Same thing. Then I click "Cancel" and go to the tree, and see many extrusions! I expected apply to terminate the task once it's successfully applied. | ||||
I see this working exactly like it is suppose to and working the way it does has many practical applications. If anything is wrong, it would be the labeling of the "Cancel" button. In the latest 0.14 versions, that "Cancel" button has been relabeled "Close" as it should be. |
Ok, so I think my suggestion is more a feature request to Improve feedback after extrude. Adding a message under the button such as "Extruded <shape> as <solid>" |
An "Apply" button never closes a panel but as its text says only applies changes. The extrusion panel now has a status label telling the user that an operation succeeded or failed and there is now an OK button too which closes the panel afterwards. |
| 2013-12-18 18:49 | mistria | New Issue | |
| 2013-12-18 20:14 | quick61 | Note Added: 0003947 | |
| 2013-12-18 20:17 | quick61 | Note Edited: 0003947 | |
| 2013-12-18 21:19 | mistria | Note Added: 0003948 | |
| 2014-01-02 12:53 | wmayer | Note Added: 0003999 | |
| 2014-01-02 12:57 | wmayer | Changeset attached | => FreeCAD Master master 68c8d98e |
| 2014-01-02 12:57 | wmayer | Assigned To | => wmayer |
| 2014-01-02 12:57 | wmayer | Status | new => closed |
| 2014-01-02 12:57 | wmayer | Resolution | open => fixed |
