| 0001338 | Arch | Bug | public | 2013-12-26 11:14 | 2014-01-01 15:43 |
| Reporter | ok0011 | Assigned To | yorik | ||
| Platform | amd64 | OS | Linux | OS Version | Linux wheezy |
| Summary | 0001338: Not correct codepage in locale | ||||
| Description | When I added items, in the options displayed incorrect codepage. May be cp1251, but my locale codepage utf-8. Language is Russian. | ||||
| Steps To Reproduce | Set Russian language. Click create wall object. ??????????? (Arch)-> ????? (Wall) | ||||
Can you check if other task dialogs (for example in the sketcher) are displaying correctly? This would narrow the possibilities... Thanks! |
Other dialogs displaying correctly. Not fine show create "Wall", "Structure". |
Okay, I'll try to fix that then. |
| 2013-12-26 11:14 | ok0011 | New Issue | |
| 2013-12-26 11:14 | ok0011 | File Added: freecad_bug.png | |
| 2013-12-26 13:37 | yorik | Note Added: 0003982 | |
| 2013-12-26 13:38 | yorik | Assigned To | => yorik |
| 2013-12-26 13:38 | yorik | Status | new => assigned |
| 2013-12-27 05:58 | ok0011 | Note Added: 0003983 | |
| 2013-12-27 13:45 | yorik | Note Added: 0003984 | |
| 2014-01-01 15:43 | yorik | Changeset attached | => FreeCAD Master master f3a4c361 |
| 2014-01-01 15:43 | yorik | Status | assigned => closed |
| 2014-01-01 15:43 | yorik | Resolution | open => fixed |
