| 0001340 | FreeCAD | Bug | public | 2013-12-28 15:41 | 2014-01-11 12:44 |
| Reporter | andri_ch | Assigned To | wmayer | ||
| Platform | Linux | OS | Ubuntu | OS Version | 13.10 |
| Summary | 0001340: Freecad crashes when creating a new document or opening a document | ||||
| Description | Freecad opens up normally, but when you want a new empty document, or open a document after you chose the file from the file dialog, it crashes. | ||||
| Steps To Reproduce | Create a new empty document. | ||||
| Additional Information | FreeCAD 0.14, Libs: 0.14R2913 (Git) $ uname -a 3.5.0-27-generic 0000046-Ubuntu SMP Mon Mar 25 20:00:05 UTC 2013 i686 i686 i686 GNU/Linux I started it at the cmd line with $ freecad -l Coin error in SoGroup::insertChild(): idx -1254965260 is out of bounds (groupnode # children == 0) freecad: SoGroup.cpp:281: virtual SoNode* SoGroup::getChild(int) const: Assertion `(index >= 0) && (index < this->getNumChildren())' failed. Aborted (core dumped) | ||||
Did you build FreeCAD yourself? Can you check which version of Coin3d FreeCAD depends on and which version of Coin3d the SoQt library depends on? And can you start FreeCAD in the debugger? |
No, I did not build FreeCAD myself. I updated freecad today to git revision 2914, but the issue persists. Using ldd, I've found that Freecad depends on libcoin60, Version: 3.1.3-2.2 and SoQt depends on libcoin80, Version 3.1.4~abc9f50-3. I started Freecad in gdb debugger, and I've attached the backtrace file: my_issue_rev_2914.log |
> Using ldd, I've found that Freecad depends on libcoin60, Version: 3.1.3-2.2 and SoQt depends on libcoin80, Version 3.1.4~abc9f50-3. And that's exactly the problem. So, you have to make sure that FreeCAD also links libcoin80 only. It's best to uninstall libcoin60 and its dev files and install the dev files of libcoin80. |
When I purged libcoin60 using apt package manager, it also uninstalled freecad, which I thought is alright because I can install it later on. Now I can't install freecad, because I have freecad 0.14+git201401042220~ubuntu13.04.1 on my 'aptitude show freecad', which does require libcoin60, not libcoin80. And libcoin60, after an ubuntu update, dissappeared from my sources list, now I have only libcoin80. Although I have this repository in my apt sources.list: http://ppa.launchpad.net/freecad-maintainers/freecad-daily/ubuntu raring main which means I get the latest freecad version, but it still requires libcoin60. |
Look here: http://packages.ubuntu.com/search?keywords=libcoin&searchon=names&suite=raring§ion=all Ubuntu 13.04 doesn't have libcoin80 but only libcoin60 And http://packages.ubuntu.com/raring/libsoqt4-20 libSoQt has a correct dependency to libcoin60 And http://bazaar.launchpad.net/~freecad-maintainers/freecad/packaging.raring/view/head:/debian/control The .deb package requests the correct versions of Coin and SoQt. First, I thought that FreeCAD might be the problem but it appeared that your local SoQt version is the culprit. For any reason you have one that links the wrong Coin version. |
FWIW, I have exactly the same problem on Ubuntu 13.10. |
I installed freecad 0.13.1830-dfsg-3, which is the stable release and works well, it uses only libcoin80. So, I dumped freecad 0.14+git201401042220~ubuntu13.04.1 which worked on my Ubuntu 13.04 but is not appropriate for my Ubuntu 13.10 because it requires libcoin60, which I don't have in my sources list. After all, freecad problems started after I upgraded Ubuntu from 13.04 to 13.10, because I had 2 freecad sources: ppa.launchpad.net_freecad-maintainers_freecad-daily_ubuntu_dists_raring_main_bi nary-i386_Packages which was fine for ubuntu 13.04 - that's the freecad version I used, and ro.archive.ubuntu.com_ubuntu_dists_saucy_universe_binary-i386_Packages which offers the stable freecad 0.13.1830-dfsg-3 which I'm now using. |
I got Freecad going on Ubuntu 13.10 by purging libcoin60 and installing libcoin80 using Synaptic. |
> So, I dumped freecad 0.14+git201401042220~ubuntu13.04.1 which worked on my Ubuntu 13.04 but is not appropriate for my Ubuntu 13.10 because it requires libcoin60, which I don't have in my sources list. Using the PPA of an older Ubuntu version doesn't work because you get a dependency mess there. Does it work to use the FreeCAD PPA for Saucy? > I got Freecad going on Ubuntu 13.10 by purging libcoin60 and installing libcoin80 using Synaptic. Since you both have FreeCAD working again can this ticket be closed? |
Yes, it can be closed. |
| 2013-12-28 15:41 | andri_ch | New Issue | |
| 2013-12-28 15:41 | andri_ch | File Added: FreeCAD.log | |
| 2013-12-29 09:06 | wmayer | Note Added: 0003985 | |
| 2013-12-29 17:07 | andri_ch | File Added: my_issue_rev_2914.log | |
| 2013-12-29 17:12 | andri_ch | Note Added: 0003989 | |
| 2013-12-29 17:13 | andri_ch | Note Edited: 0003989 | |
| 2013-12-30 13:11 | wmayer | Note Added: 0003991 | |
| 2014-01-05 22:50 | andri_ch | Note Added: 0004026 | |
| 2014-01-05 23:44 | andri_ch | Note Edited: 0004026 | |
| 2014-01-06 13:16 | wmayer | Note Added: 0004027 | |
| 2014-01-07 20:46 | danilius | Note Added: 0004031 | |
| 2014-01-08 16:54 | andri_ch | Note Added: 0004032 | |
| 2014-01-08 16:55 | andri_ch | Note Edited: 0004032 | |
| 2014-01-09 10:50 | danilius | Note Added: 0004034 | |
| 2014-01-11 12:27 | wmayer | Note Added: 0004043 | |
| 2014-01-11 12:43 | andri_ch | Note Added: 0004046 | |
| 2014-01-11 12:44 | wmayer | Status | new => closed |
| 2014-01-11 12:44 | wmayer | Assigned To | => wmayer |
| 2014-01-11 12:44 | wmayer | Resolution | open => no change required |
