| 0001356 | Sketcher | Bug | public | 2014-01-14 13:21 | 2014-03-03 17:59 |
| Reporter | nahshon | Assigned To | wmayer | ||
| Platform | i686 | OS | Linux | OS Version | Fedora 19 |
| Summary | 0001356: Error message displays value in Radians (adding reduntant/conflicting angle constraint) | ||||
| Description | The triangle is alerady rigid, adding an error should produce a redundant or conflicting constraint. I did not expect to see the error message with value in Radians. | ||||
| Steps To Reproduce | Create a triangle and add length constraints to all 3 edges. (I use lengths 30, 40, 50 to create a right-angle). Now add the angle constraint on the right angle.Preass OK on the dialog (do not change the 90 degrees dimension). Error message is displayed. | ||||
| Additional Information | I expect that error messages should use the same units / dimensions as the rest of FreeCAD. | ||||
FreeCAD: master 874f61e1 2014-03-03 17:19:33 Details Diff |
+ fixes 0001356: Error message displays value in Radians (adding reduntant/conflicting angle constraint) |
Affected Issues 0001356 |
| mod - src/Mod/Sketcher/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Sketcher/App/SketchObjectPyImp.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/EditDatumDialog.cpp | Diff File | ||
| 2014-01-14 13:21 | nahshon | New Issue | |
| 2014-01-14 13:21 | nahshon | File Added: dimension-error.png | |
| 2014-03-03 17:59 | wmayer | Changeset attached | => FreeCAD Master master 874f61e1 |
| 2014-03-03 17:59 | wmayer | Assigned To | => wmayer |
| 2014-03-03 17:59 | wmayer | Status | new => closed |
| 2014-03-03 17:59 | wmayer | Resolution | open => fixed |
