| 0001359 | FreeCAD | Patch | public | 2014-01-17 09:46 | 2014-01-18 11:12 |
| Reporter | shoogen | Assigned To | wmayer | ||
| Summary | 0001359: Drawing SVG output makes ever knot symetrical. | ||||
| Description | A bezier segment could be linear (degree == 1). The path elements "S" and "T" are used incorrectly. They mean the the knot is symmetrical. The seconds pole of the second segment and the second last pole of the first segment are symmetric to the common knot. AFAIK. OCCT data structures don't explicitly provide that information and it wouldn't make any sense to calculate it to save a few characters. The Output of the first segment seems to be valid the first pole is passed with the 'M' statement. The poles 2-4 are passed with the C statement. For the following segments the poles 2-4 should be passed (with a 'C' statement)*. The first pole is redundant since represent the common knot between two segments. But for further segments the second pole is omitted. And the knot interpreted to be symmetrical to the last segment (C1). Assume that you have a BSpline that C0 continuous. The given code example would never create valid SVG code except for the first segment. *) repeated statements can be omitted. | ||||
| Additional Information | patch available at: git://github.com/5263/FreeCAD.git drawing-svg | ||||
I'm still hitting the else branch because of unexpected degree. For example Degree 5 when drawing Schenkel.stp |
C0 did the trick ;) i updated my branch. So far i only for SVG output and not for DXF. |
I'm still not sure if it's better to use C0 or C1. But C2 will always return a Degree of 5. |
Merged into master |
git show 9c5f1c2 |
| 2014-01-17 09:46 | shoogen | New Issue | |
| 2014-01-17 10:27 | shoogen | Note Added: 0004086 | |
| 2014-01-17 11:02 | shoogen | Note Added: 0004088 | |
| 2014-01-17 11:46 | shoogen | Note Added: 0004089 | |
| 2014-01-18 11:11 | wmayer | Note Added: 0004092 | |
| 2014-01-18 11:12 | wmayer | Note Added: 0004093 | |
| 2014-01-18 11:12 | wmayer | Assigned To | => wmayer |
| 2014-01-18 11:12 | wmayer | Status | new => closed |
| 2014-01-18 11:12 | wmayer | Resolution | open => fixed |
| 2014-01-18 11:12 | wmayer | Fixed in Version | => 0.14 |
