| 0001365 | FreeCAD | Bug | public | 2014-01-23 21:39 | 2014-01-26 22:35 |
| Reporter | ulrich1a | Assigned To | yorik | ||
| Platform | all | ||||
| Summary | 0001365: Draft-workbench:Flatsvg export put the drawing content outside of the viewing window making it unusable in the drawing workbench | ||||
| Description | Export a draft or something else as a flatsvg produces an svg, that shows nothing, if loaded in the drawing workbench. Opening the same file in Inkscape makes it visible, that all content is outside of the viewing window. The fix is simple: line 1182 in importSVG.py hat to be changed from: svg.write('<g transform="translate('+str(-minx)+','+str(-miny+(2*margin))+') scale(1,-1)">\n') to: svg.write('<g transform="translate('+str(-minx)+','+str(maxy)+') scale(1,-1)">\n') | ||||
| Steps To Reproduce | Make something in the draft-workbench. Export it as flatsvg. Open the file in the drawing workbench. Open the file in inkscape. | ||||
| 2014-01-23 21:39 | ulrich1a | New Issue | |
| 2014-01-23 23:49 | yorik | Assigned To | => yorik |
| 2014-01-23 23:49 | yorik | Status | new => assigned |
| 2014-01-23 23:50 | yorik | Note Added: 0004119 | |
| 2014-01-26 22:35 | yorik | Changeset attached | => FreeCAD Master master c3e8a157 |
| 2014-01-26 22:35 | yorik | Status | assigned => closed |
| 2014-01-26 22:35 | yorik | Resolution | open => fixed |
