| 0001372 | FreeCAD | Bug | public | 2014-01-29 09:37 | 2014-02-04 15:51 |
| Reporter | Fulminictus | Assigned To | yorik | ||
| Platform | Linux | OS | KUbuntu | OS Version | 13.10 AMD64 |
| Summary | 0001372: Awfully slow Sketcher | ||||
| Description | While drawing a relatively simple sketch with part design, the interface gets awfully slow. If I add a single line to the sketch, the GUI freezes >1 Minute until the next line can be added. The FreeCAD process consumes 100% of one CPU core during this freeze. The sketcher is unusable this way. | ||||
| Steps To Reproduce | Open attached drawing Switch to Part Design Open sketch MZ8 Use line tool to add a single line somewhere to the sketch. | ||||
| Additional Information | FreeCad release if 0.14 3066 (Git) from 2014/01/27 64-bit Hardware Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz 16GB RAM GfX AMD 7970 | ||||
If you use part design/validate sketch, you will see that you are missing some coincidence constraints. Meaning you have small gaps at the end points. Yet you have a completely constrained sketch. This will not behave as you expect. You can use the validate sketch tool and add the missing constraints, but that will lead you to many redundant constraints. I suggest you start over and keep sketches simple and use polar array. Depending upon your experience, you should start on the help forum and let seasoned veterans explore your problems and help determine if there is a new bug worthy of a mantis ticket. Good luck. Too admins: I don't see a new bug here. |
Me neither. I'll close this, as there is nothing really required on our part. Feel free to reopen if needed. |
| 2014-01-29 09:37 | Fulminictus | New Issue | |
| 2014-01-29 09:37 | Fulminictus | File Added: SlowSketcher_in_simple_design.fcstd | |
| 2014-01-29 14:30 | tanderson69 | Note Added: 0004129 | |
| 2014-02-04 15:51 | yorik | Note Added: 0004146 | |
| 2014-02-04 15:51 | yorik | Status | new => closed |
| 2014-02-04 15:51 | yorik | Assigned To | => yorik |
| 2014-02-04 15:51 | yorik | Resolution | open => no change required |
| 2014-02-04 15:51 | yorik | Fixed in Version | => 0.14 |
