| 0001376 | Draft | Feature | public | 2014-01-30 21:27 | 2014-03-23 20:49 |
| Reporter | ulrich1a | Assigned To | yorik | ||
| Platform | all | ||||
| Summary | 0001376: Draft projection: Using a direction should give the same projection in Drawing and Draft-Workbench | ||||
| Description | I want to combine Draft-Dimensions with Drawing-projections. This works only in special cases. At using any other projection direction then pure z or x or y, both projections are not in sync. I modified in WorkingPlane.py the function: def alignToPointAndAxis(self, point, axis, offset, upvec=None): in order to get the same projection from the Draft and the Drawing workbench. See this post: http://forum.freecadweb.org/viewtopic.php?f=3&t=5392#p44617 The function is also used in other Workbenches (Arch). I have not enough knowledge to do the right tests, in order to check if this will give problems or not. Having the same projection in all cases, makes dimensioned drawings much easier. | ||||
| Additional Information | OS: Debian GNU/Linux 7.3 (wheezy) Platform: 32-bit Version: 0.14.3069 (Git) Branch: master Hash: a7d297c33d6b3f8a1758413eae192304a4f2c208 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 SoQt version: 1.5.0 | ||||
I got some working code. I posted it here: http://forum.freecadweb.org/viewtopic.php?f=3&t=5392&start=10#p45651 Ulrich |
Yorik did you have a look at the code in the post above? This is a version that solves the problems. It calculates the same u and v vectors as the occ-code on the fly. Ulrich |
I have a very hard time figuring out where your code differs from the current code... Can you post a diff? |
0001-Makes-Draft-Drawing-Projection-in-sync-with-Drawing-.patch (4,306 bytes)
From a1d9268cebc38f7b9906193daca8a2d573733d1c Mon Sep 17 00:00:00 2001
Date: Tue, 18 Mar 2014 19:37:39 +0100
Subject: Makes Draft-Drawing-Projection in sync with Drawing-Projection
src/Mod/Draft/Draft.py | 2 +-
src/Mod/Draft/WorkingPlane.py | 58 +++++++++++++++++++++++++++++++++++++++++
2 files changed, 59 insertions(+), 1 deletion(-)
diff --git a/src/Mod/Draft/Draft.py b/src/Mod/Draft/Draft.py
index 8bd7c60..2c7c98e 100644
--- a/src/Mod/Draft/Draft.py
+++ b/src/Mod/Draft/Draft.py
@@ -1549,7 +1549,7 @@ def getSVG(obj,scale=1,linewidth=0.35,fontsize=12,fillstyle="shape color",direct
if isinstance(direction,FreeCAD.Vector):
if direction != Vector(0,0,0):
plane = WorkingPlane.plane()
- plane.alignToPointAndAxis(Vector(0,0,0),direction.negative(),0)
+ plane.alignToPointAndAxis_SVG(Vector(0,0,0),direction.negative().negative(),0)
elif isinstance(direction,WorkingPlane.plane):
plane = direction
diff --git a/src/Mod/Draft/WorkingPlane.py b/src/Mod/Draft/WorkingPlane.py
index 25a0c3f..69207bd 100644
--- a/src/Mod/Draft/WorkingPlane.py
+++ b/src/Mod/Draft/WorkingPlane.py
@@ -136,6 +136,64 @@ class plane:
# FreeCAD.Console.PrintMessage("(position = " + str(self.position) + ")\n")
# FreeCAD.Console.PrintMessage("Current workplane: x="+str(DraftVecUtils.rounded(self.u))+" y="+str(DraftVecUtils.rounded(self.v))+" z="+str(DraftVecUtils.rounded(self.axis))+"\n")
+ def alignToPointAndAxis_SVG(self, point, axis, offset):
+ # based on cases table
+ self.doc = FreeCAD.ActiveDocument
+ self.axis = axis;
+ self.axis.normalize()
+ ref_vec = Vector(0.0, 1.0, 0.0)
+ if ((abs(axis.x) > abs(axis.y)) and (abs(axis.y) > abs(axis.z))):
+ ref_vec = Vector(0.0, 0., 1.0)
+ self.u = axis.negative().cross(ref_vec)
+ self.u.normalize()
+ self.v = DraftVecUtils.rotate(self.u, math.pi/2, self.axis)
+ #projcase = "Case new"
+ elif ((abs(axis.y) > abs(axis.z)) and (abs(axis.z) >= abs(axis.x))):
+ ref_vec = Vector(1.0, 0.0, 0.0)
+ #projcase = "Y>Z, View Y"
+ elif ((abs(axis.y) >= abs(axis.x)) and (abs(axis.x) > abs(axis.z))):
+ self.u = axis.cross(ref_vec)
+ #projcase = "ehem. XY, Case XY"
+ elif ((abs(axis.x) > abs(axis.z)) and (abs(axis.z) >= abs(axis.y))):
+ #projcase = "X>Z, View X"
+ elif ((abs(axis.z) >= abs(axis.y)) and (abs(axis.y) > abs(axis.x))):
+ ref_vec = Vector(1.0, 0., 0.0)
+ #projcase = "Y>X, Case YZ"
+ else:
+ #projcase = "else"
+ #spat_vec = self.u.cross(self.v)
+ #spat_res = spat_vec.dot(axis)
+ #FreeCAD.Console.PrintMessage(projcase + " spat Prod = " + str(spat_res) + "\n")
+ offsetVector = Vector(axis); offsetVector.multiply(offset)
+ self.position = point.add(offsetVector)
+ self.weak = False
+ # FreeCAD.Console.PrintMessage("(position = " + str(self.position) + ")\n")
+ # FreeCAD.Console.PrintMessage("Current workplane: x="+str(DraftVecUtils.rounded(self.u))+" y="+str(DraftVecUtils.rounded(self.v))+" z="+str(DraftVecUtils.rounded(self.axis))+"\n")
def alignToCurve(self, shape, offset):
if shape.ShapeType == 'Edge':
#??? TODO: process curve here. look at shape.edges[0].Curve
1.7.10.4
I did upload a patch to this Feature-request. Ulrich |
Okay i just tested and merged your patch, there are still inversions compared to the Drawing module projection direction, but the correct placement on the sheet is already a big improvement. Thanks! |
| 2014-01-30 21:27 | ulrich1a | New Issue | |
| 2014-02-04 11:16 | yorik | Assigned To | => yorik |
| 2014-02-04 11:16 | yorik | Status | new => assigned |
| 2014-02-04 15:09 | yorik | Project | FreeCAD => Draft |
| 2014-02-09 22:52 | ulrich1a | Note Added: 0004177 | |
| 2014-02-12 21:29 | ulrich1a | Note Added: 0004202 | |
| 2014-03-08 20:36 | yorik | Note Added: 0004397 | |
| 2014-03-08 20:37 | yorik | Severity | major => minor |
| 2014-03-18 19:41 | ulrich1a | File Added: 0001-Makes-Draft-Drawing-Projection-in-sync-with-Drawing-.patch | |
| 2014-03-18 19:43 | ulrich1a | Note Added: 0004476 | |
| 2014-03-23 20:27 | yorik | Note Added: 0004485 | |
| 2014-03-23 20:49 | yorik | Changeset attached | => FreeCAD Master master e293d61d |
| 2014-03-23 20:49 | yorik | Status | assigned => closed |
| 2014-03-23 20:49 | yorik | Resolution | open => fixed |
