0001385FreeCADBugpublic2014-02-04 22:15
Reporterquick61 Assigned Toyorik
Status closedResolutionfixed
Fixed in Version0.14
Summary0001385: Commit [bba876] causing new errors.
DescriptionReferencing Forum post http://forum.freecad.org/viewtopic.php?f=22&t=5554&start=10#p45120 change to Draft.py is now causing new errors. Original problem remains.
Steps To ReproduceRun Macro from this post - http://forum.freecad.org/viewtopic.php?f=22&t=5554#p45080 Provide valid airfoil file, enter desired chord length and select "Make BSpline". Press OK.
yorik
2014-02-04 18:08
administrator   ~0004148
oops... fixed again in 2ee101d
quick61
2014-02-04 21:42
reporter   ~0004149
This is now working without error. Think it can be closed at your leisure. I see no ill affects using the scaling tool on BSpline objects or any other.
Related Changesets
FreeCAD: master 2ee101de
2014-02-04 19:08:09
yorik
Details Diff
Draft: fixed draft scale again - fixes 0001385 Affected Issues
0001385
mod - src/Mod/Draft/Draft.py Diff File
2014-02-04 17:35 quick61 New Issue
2014-02-04 17:50 yorik Assigned To => yorik
2014-02-04 17:50 yorik Status new => assigned
2014-02-04 18:08 yorik Note Added: 0004148
2014-02-04 21:42 quick61 Note Added: 0004149
2014-02-04 21:59 yorik Status assigned => closed
2014-02-04 21:59 yorik Resolution open => fixed
2014-02-04 21:59 yorik Fixed in Version => 0.14
2014-02-04 22:15 yorik Changeset attached => FreeCAD Master master 2ee101de
