| 0001386 | Draft | Bug | public | 2014-02-05 14:55 | 2014-03-12 15:39 |
| Reporter | jmaustpc | Assigned To | yorik | ||
| Target Version | trunk | ||||
| Summary | 0001386: Draft Move tool, not updating all property values when Line and point are moved | ||||
| Description | Draft Point can be moved with the Draft Move tool, but its XYZ value are not updated. I believe the problem is that these are the values of the XYZ properties of the point...not its xyz placement values. Draft point does not show the placement properties in the data tab Further to the above, although Draft Line works properly, if you set Draft to use Part objects...hence get a Part Line, and then use the Draft move tool on the Part line, it updates the placement values but not the Start Finish point properties. | ||||
| Steps To Reproduce | I have attached just a FreeCAD file with a Draft Point and Draft Line and a Part Line placed by changing Draft to use Part Lines, for your convenience. If you move these around with the Draft Move tool, and observe the changes or lack there of, in the various property values in Data Tab, you will see these issues. | ||||
| 2014-02-05 14:55 | jmaustpc | New Issue | |
| 2014-02-05 14:55 | jmaustpc | Status | new => assigned |
| 2014-02-05 14:55 | jmaustpc | Assigned To | => yorik |
| 2014-02-05 14:55 | jmaustpc | File Added: DraftPoint_DraftLine_PartLine.fcstd | |
| 2014-02-05 15:06 | yorik | Note Added: 0004151 | |
| 2014-02-05 18:34 | yorik | Note Added: 0004154 | |
| 2014-02-08 03:06 | yorik | Project | FreeCAD => Draft |
| 2014-03-12 15:39 | yorik | Changeset attached | => FreeCAD Master master 23c44905 |
| 2014-03-12 15:39 | yorik | Status | assigned => closed |
| 2014-03-12 15:39 | yorik | Resolution | open => fixed |
