| 0001390 | PartDesign | Bug | public | 2014-02-06 16:54 | 2014-03-04 10:44 |
| Reporter | Geoplace | Assigned To | wmayer | ||
| Platform | 32-bit | OS | Windows XP | OS Version | 2002 SP3 |
| Summary | 0001390: Can't modify or edit an sketch at a Face | ||||
| Description | An sketch leave open like "U" figure (not a close perimeter) at a face can´t be modified with part design workbench. -Unhandled std::exception caught on GUIApplication::notify.The error message is Access Violation – No RTTI data! -Unhandled Base::exception caught on GUIApplication::notify.The error message is Unknown document " -The file menu is inactive. | ||||
| Steps To Reproduce | 1. Open the attached File: 00_PartExtrude 2. Use the Part Design Workbench. 3. Secondary Click on: "Sketch001" at Tree View and option "Edit" 4. At the Tasks Tab, click on any "Constraint" element. The status bar shows message: -Unhandled std::exception caught on GUIApplication::notify.The error message is Access Violation – No RTTI data! 5. The tools for sketches stay inactive and 6. I Can't close the edit sketch task. When I click the "close" button the status bar shows message: -Unhandled Base::exception caught on GUIApplication::notify.The error message is Unknown document " 7. Also when I close all the files open The File Menu has all its options inactive, except the "Recent files". I can't exit the application from there or create a new file. 8. I need to restart FreedCad to be able to draw other sketches again. | ||||
| Additional Information | FreeCAD Version: 0.13.1828 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.3.0 | ||||
I think this is the result of a bad model and not a bug, and should have been brought up in the forum before a ticket was filed. "Sketch" is underconstrained and not closed; there is no Coincident Constraint between endpoints of the lines at the origin. I constrained all existing points to whatever value came up in the Insert Datum window except that unconstrained point at the origin. Only then I added a coincident constraint to constrain that last point to the origin. This way none of the other points moved first. Deleted "Sketch001" and created a new U shaped sketch on that face, closed Sketcher, then opened "Sketch001" to edit it; no problem. Oddly the original "Pad" is a solid and passed Check Geometry, so I think the two endpoints originally did have a coincident constraint applied and it was subsequently deleted. Saved in the uploaded file 20140205a_Ticket_1390.FCStd. |
I removed all the constraints from the sketch and started moving geometry around. There are 4 arcs in the sketch that were not visible before editing. I agree with bejant and I don't think there is a new bug here. |
So why I can't close the edit mode of "Scketch001". The software must provide the user with feedback to inform any design conflict. Because in that scenario (editing the scektch001) the software seems like blocked with no useful info of why. A robust and friendly software must be fool's proof. |
I can confirm all this with 0.13. Having an apparently wrong sketch should not cause all these troubles. |
With the developer version for 0.14 this all works correctly now. Not sure by which commit this was fixed but I remember similar effect a while ago. |
| 2014-02-06 16:54 | Geoplace | New Issue | |
| 2014-02-06 16:54 | Geoplace | File Added: 00_PartExtrude.FCStd | |
| 2014-02-06 19:12 | bejant | File Added: 20140205a_Ticket_1390.FCStd | |
| 2014-02-06 19:18 | bejant | Note Added: 0004158 | |
| 2014-02-06 20:59 | tanderson69 | Note Added: 0004159 | |
| 2014-02-09 01:15 | Geoplace | Note Added: 0004172 | |
| 2014-03-04 10:43 | wmayer | Note Added: 0004376 | |
| 2014-03-04 10:43 | wmayer | Assigned To | => wmayer |
| 2014-03-04 10:43 | wmayer | Status | new => confirmed |
| 2014-03-04 10:44 | wmayer | Note Added: 0004377 | |
| 2014-03-04 10:44 | wmayer | Status | confirmed => closed |
| 2014-03-04 10:44 | wmayer | Resolution | open => fixed |
| 2014-03-04 10:44 | wmayer | Fixed in Version | => 0.14 |
