0001398FreeCADBugpublic2014-03-15 13:05
Reporterfasaxc Assigned Towmayer
PlatformLinuxOSUbuntuOS Version13.04
Product Version0.13
Summary0001398: View controls get confused, continue rotating even after buttons are released
DescriptionWhen rotating a part in part design mode, sometimes it gets stuck in rotation mode and keeps spinning. Other times, it gets stuck in zoom or pan mode even though I've released the buttons.
Steps To ReproduceUsing a mouse, in the part design workbench I use middle+right button to rotate the part. I release the buttons but it carries on rotating. It seems to happen less if I'm careful to release the RMB first and then wait a beat before releasing the middle mouse button.
Similar problems with zooming and panning. Sometimes it gets stuck and middle+right will no longer rotate.
Hitting the "top view" button resets the view and it starts working again.
2014-02-10 12:30
administrator   ~0004178
This is intended. If you don't want it go to Edit > Preferences > Display and switch off "Enable animation".
fasaxc
2014-02-11 02:19
reporter   ~0004181
If it's intended, what am I doing to activate it and how do I stop it once it's started? Hitting escape was my instinct to get out of it but that does something different.
2014-02-11 10:18
administrator   ~0004183
Simply do a left click inside the 3d view to stop the animation.
2014-02-10 01:34 fasaxc New Issue
2014-02-10 12:30 wmayer Note Added: 0004178
2014-02-10 14:38 wmayer Note Edited: 0004178
2014-02-11 02:19 fasaxc Note Added: 0004181
2014-02-11 10:18 wmayer Note Added: 0004183
2014-03-03 11:46 wmayer Severity major => minor
2014-03-15 13:05 wmayer Status new => closed
2014-03-15 13:05 wmayer Assigned To => wmayer
2014-03-15 13:05 wmayer Resolution open => no change required
