| 0001402 | FreeCAD | Bug | public | 2014-02-11 18:22 | 2014-02-11 23:19 |
| Reporter | quick61 | Assigned To | |||
| Summary | 0001402: Part Design > Pad length values changed and set to 100mm on opening older files with latest version of FreeCAD | ||||
| Description | Forum thread > http://forum.freecadweb.org/viewtopic.php?f=3&t=5658 Opening older FreeCAD files that were built with sketches, all of the pad operations have a length value of 100 mm applied to them. The length value in the Combo View > Data tab can not be changed. The numbers will change but any attempt to apply will not take and the value returns to 100. | ||||
| Steps To Reproduce | Open a FreeCAD file containing padded sketches created with an older version of FreeCAD with current build. Look for bug as described. | ||||
From Report View when trying to change length value of Pad from Combo-View - Data tab. <unknown exception traceback><type 'exceptions.SyntaxError'>: ('invalid syntax', ('<string>', 1, 68, 'FreeCAD.getDocument("V_Carrage").getObject("Pad004").Length = 100 mm\n')) Stack Trace: <unknown exception traceback> |
| 2014-02-11 18:22 | quick61 | New Issue | |
| 2014-02-11 18:37 | quick61 | Note Added: 0004185 | |
| 2014-02-11 18:41 | quick61 | Note Edited: 0004185 | |
| 2014-02-11 19:12 |
Assigned To | => Jriegel |
| 2014-02-11 19:12 |
Status | new => assigned |
| 2014-02-11 19:15 |
Status | assigned => confirmed |
| 2014-02-11 22:29 |
Changeset attached | => FreeCAD Master master 82ff6447 |
| 2014-02-11 23:19 |
Status | confirmed => closed |
| 2014-02-11 23:19 |
Resolution | open => fixed |
