| 0001404 | Draft | Patch | public | 2014-02-11 23:05 | 2014-05-11 17:45 |
| Reporter | ulrich1a | Assigned To | yorik | ||
| Platform | all | ||||
| Summary | 0001404: Draft Dimension Override string: Non ascii-Characters are not shown in Drawings | ||||
| Description | As the summary says: Non ascii-characters are not shown in Drawings. This is a regression after the Pyside migration. I made a patch, that corrects the behavior. | ||||
| Steps To Reproduce | - Make a dimension. - Put any Latin1 but non ascii-Character like "Ü" into the override string. - Put the dimension in a Drawing. an error message appears about a non asci-character. | ||||
0001-Renables-non-asci-characters-in-the-Override-string-.patch (2,694 bytes)
From 98ad6fe25d30b3c1b1c79ae4169fe6501f05e9e6 Mon Sep 17 00:00:00 2001
Date: Tue, 11 Feb 2014 23:49:47 +0100
Subject: Renables non-asci characters in the Override string in Drawing
projections
src/Mod/Draft/Draft.py | 29 +++++++++++++++--------------
1 file changed, 15 insertions(+), 14 deletions(-)
diff --git a/src/Mod/Draft/Draft.py b/src/Mod/Draft/Draft.py
index 55dc894..f083c9a 100644
--- a/src/Mod/Draft/Draft.py
+++ b/src/Mod/Draft/Draft.py
@@ -1636,20 +1636,20 @@ def getSVG(obj,scale=1,linewidth=0.35,fontsize=12,fillstyle="shape color",direct
return svg
def getText(color,fontsize,fontname,angle,base,text):
- svg = '<text fill="'
- svg += getrgb(color) +'" font-size="'
+ svg = u'<text fill="'
+ svg += getrgb(color) +u'" font-size="'
svg += str(fontsize) + '" '
- svg += 'style="text-anchor:middle;text-align:center;'
- svg += 'font-family:'+ fontname +'" '
- svg += 'transform="rotate('+str(math.degrees(angle))
- svg += ','+ str(base.x) + ',' + str(base.y) + ') '
- svg += 'translate(' + str(base.x) + ',' + str(base.y) + ') '
+ svg += u'style="text-anchor:middle;text-align:center;'
+ svg += u'font-family:'+ fontname +'" '
+ svg += u'transform="rotate('+str(math.degrees(angle))
+ svg += u','+ str(base.x) + ',' + str(base.y) + u') '
+ svg += u'translate(' + str(base.x) + u',' + str(base.y) + u') '
#svg += 'scale('+str(tmod/2000)+',-'+str(tmod/2000)+') '
- svg += 'scale(1,-1) '
- svg += '" freecad:skip="1"'
- svg += '>\n'
- svg += text
- svg += '</text>\n'
+ svg += u'scale(1,-1) '
+ svg += u'" freecad:skip="1"'
+ svg += u'>\n'
+ svg += text.decode('utf-8')
+ svg += u'</text>\n'
return svg
@@ -3109,8 +3109,9 @@ class _ViewProviderDimension(_ViewProviderDraft):
fstring = "%." + str(getParam("dimPrecision",2)) + "f"
self.string = (fstring % l)
if obj.ViewObject.Override:
- self.string = unicode(obj.ViewObject.Override).encode("latin1").replace("$dim",self.string)
- self.text.string = self.text3d.string = self.string
+ self.string = unicode(obj.ViewObject.Override).encode("utf-8").replace("$dim",self.string)
+ self.text.string = self.string.decode('utf-8').encode('latin1')
+ self.text3d.string = self.string.decode('utf-8').encode('latin1')
# set the distance property
if round(obj.Distance,precision()) != round(l,precision()):
1.7.10.4
have you tested the patch with non latin1 characters? like € |
Thanks! I'll test and apply if all is OK. |
Yes I tested the patch with a non latin1 character. It gives an error at that line where the string is coded to latin1. This is expected and it was the same without the patch. So the non latin1 character is not shown in the 3D-view. (It is a coin-3D-defiency.) But with this patch the character is shown in a Drawing projection. Since the PySide-Migration only ascii-characters are shown in the Drawing projection. So this patch allows utf-8 in a Drawing projection. I had a discussion with a programmer. He gave me a hint how to avoid the encoding to utf-8. I will add another version of this patch. |
shoogen and I also don't like much turning the SVG output into an unicode object... This might cause problems in other parts of FreeCAD that expect standard strings. We might need to change that. |
0001-Enable-unicode-in-Drawing-Dimensions.patch (3,034 bytes)
From dc4625b4314cb8a6235c941586048f106be9d30c Mon Sep 17 00:00:00 2001
Date: Wed, 12 Feb 2014 22:02:54 +0100
Subject: Enable unicode in Drawing Dimensions
src/Mod/Draft/Draft.py | 35 ++++++++++++++++++-----------------
1 file changed, 18 insertions(+), 17 deletions(-)
index 55dc894..b83355e 100644
return svg
- svg += str(fontsize) + '" '
+ svg += str(fontsize) + u'" '
+ svg += u'font-family:'+ fontname +u'" '
- svg += '>\n'
+ svg += u'>\n'
svg += text
return svg
@@ -3104,13 +3104,14 @@ class _ViewProviderDimension(_ViewProviderDraft):
# set text value
l = self.p3.sub(self.p2).Length
if hasattr(obj.ViewObject,"Decimals"):
- fstring = "%." + str(obj.ViewObject.Decimals) + "f"
+ fstring = u"%." + unicode(obj.ViewObject.Decimals) + u"f"
else:
- fstring = "%." + str(getParam("dimPrecision",2)) + "f"
- self.string = (fstring % l)
+ fstring = u"%." + unicode(getParam("dimPrecision",2)) + u"f"
+ self.string = unicode(fstring % l)
+ self.string = unicode(obj.ViewObject.Override).replace(u"$dim",self.string)
+ self.text.string = self.string.encode("latin1")
+ self.text3d.string = self.string.encode("latin1")
1.7.10.4
These are different things. You can leave out the "u" before the string objects. Then you have still an asci-string but with an utf-8 encoding in it. This is fully conform to SVG-standards. I did look that up. There is still the regression, that the non asci-characters are not shown in the override string in a Drawing projection. This is solved by the patch and it should also be solved with a version without the "u"s before the string objects. So my second version seems of no use. I did not see problems with it so far. Ulrich |
the problem with the "svg" string being a unicode objects, starts when is has to be processed outside of python. In this case care must be taken when writing to a file. I don't like the fact the the replacement for "$dim" happens on an already decoded string. I haven't spent much time testing. But we should surely offer a (fallback) replacement strategy when encoding to latin1 to avoid encoding errors t.string = s.decode("utf8").encode("latin1","replace") |
0002-Latin1-Filter-implementation.patch (1,682 bytes)
From c6c32c25cc6f614151441152e32143ef6b515fb8 Mon Sep 17 00:00:00 2001
Date: Sat, 15 Feb 2014 00:20:09 +0100
Subject: Latin1 Filter implementation
src/Mod/Draft/Draft.py | 14 ++++++++++++--
1 file changed, 12 insertions(+), 2 deletions(-)
index b83355e..0e2d715 100644
@@ -3004,6 +3004,16 @@ class _ViewProviderDimension(_ViewProviderDraft):
self.onChanged(vobj,"FontName")
self.onChanged(vobj,"ArrowType")
self.onChanged(vobj,"LineColor")
+ def latin1_filter(self, filter_text):
+ latin_text = ''
+ for i in range(len(filter_text)):
+ if ord(filter_text[i])<256:
+ latin_text += filter_text[i]
+ else:
+ latin_text += ' '
+ return latin_text.encode('latin1')
def updateData(self, obj, prop):
"called when the base object is changed"
@@ -3110,8 +3120,8 @@ class _ViewProviderDimension(_ViewProviderDraft):
- self.text.string = self.string.encode("latin1")
- self.text3d.string = self.string.encode("latin1")
+ self.text.string = self.latin1_filter(self.string)
+ self.text3d.string = self.latin1_filter(self.string)
1.7.10.4
I made a filter in order to get only latin1 characters into the 3D-presentation. It works for me. (Using the last two patches.) I tested so far with Arial in the font setting. I can save and load the SVG-drawing. What else needs to be tested? |
Apparently, starting from Coin3D 4.0 (libcoin80), utf characters are now fully supported. I just committed a change that fixes that, now all texts (Draft Texts and Draft Dimensions) can have utf8 characters, which display coherently in the Properties editor, the 3D view, and the SVG Drawing sheets. I still left a fallback for people who have an older version of coin. The annexed test_utf8_in_draft.fcstd file contains example of such texts, which should render 100% correctly with coin4, and possibly with encoding errors on older versions, but at least not crash. Please test! I'll still leave this issue open in case there are still problems |
I just tested without Coin3D version 4.0. The fallback solution has a problem in the 3D-View. I made an Draft-dimension and put "$dim Ü" in the override. I get "10.0 Ã" in the 3D-view. But the "Ü" is shown correct in a Drawing projection. A step forward, but a small issue is left. |
Ok so the Ü (which is unicode, therefore works ok in the interface and on the svg sheet), must be converted to latin1 when using coin < 4. This is obviously not optimal (some utf8 chars don't exist in latin1) but I suppose it's the best we can do... |
Just committed a fix (commit 32d7839) that takes the coin verison into account, and converts texts to latin1 if coin version is < 4. Please test! Thanks |
I believe this is now fixed, reopen if needed! |
FreeCAD: master 749a8fa1 2014-03-29 18:31:45 Details Diff |
Draft - enabled utf8 in coin3d and svg - relates to issue 0001404 |
Affected Issues 0001404 |
FreeCAD: master 96967a51 2014-04-19 18:26:24 Details Diff |
Draft: further fix for utf8 texts - issue 0001404 |
FreeCAD: master 32d7839d 2014-05-03 18:00:44 Details Diff |
Draft: use latin1 in texts if coin < 4 - issue 0001404 |
| 2014-02-11 23:05 | ulrich1a | New Issue | |
| 2014-02-11 23:05 | ulrich1a | File Added: 0001-Renables-non-asci-characters-in-the-Override-string-.patch | |
| 2014-02-12 12:24 | shoogen | Note Added: 0004190 | |
| 2014-02-12 12:25 | shoogen | Relationship added | parent of 0000853 |
| 2014-02-12 12:52 | yorik | Assigned To | => yorik |
| 2014-02-12 12:52 | yorik | Status | new => assigned |
| 2014-02-12 12:53 | yorik | Note Added: 0004193 | |
| 2014-02-12 19:57 | ulrich1a | Note Added: 0004198 | |
| 2014-02-12 20:13 | yorik | Note Added: 0004199 | |
| 2014-02-12 21:15 | ulrich1a | File Added: 0001-Enable-unicode-in-Drawing-Dimensions.patch | |
| 2014-02-12 21:25 | ulrich1a | Note Added: 0004201 | |
| 2014-02-12 23:43 | shoogen | Note Added: 0004203 | |
| 2014-02-15 17:34 | ulrich1a | File Added: 0002-Latin1-Filter-implementation.patch | |
| 2014-02-15 17:38 | ulrich1a | Note Added: 0004224 | |
| 2014-03-08 20:40 | yorik | Severity | major => minor |
| 2014-03-29 17:32 | yorik | File Added: test utf8 in draft.fcstd | |
| 2014-03-29 17:38 | yorik | Note Added: 0004515 | |
| 2014-03-29 17:38 | yorik | Status | assigned => feedback |
| 2014-03-29 17:59 | yorik | Changeset attached | => FreeCAD Master master 749a8fa1 |
| 2014-03-29 19:49 | yorik | Project | FreeCAD => Draft |
| 2014-03-30 13:19 | ulrich1a | Note Added: 0004520 | |
| 2014-03-30 13:19 | ulrich1a | Status | feedback => assigned |
| 2014-03-30 15:47 | yorik | Note Added: 0004521 | |
| 2014-04-19 16:48 | yorik | Changeset attached | => FreeCAD Master master 96967a51 |
| 2014-05-03 15:48 | yorik | Product Version | trunk => |
| 2014-05-03 15:48 | yorik | Target Version | => 0.14 |
| 2014-05-03 16:04 | yorik | Note Added: 0004611 | |
| 2014-05-03 16:28 | yorik | Changeset attached | => FreeCAD Master master 32d7839d |
| 2014-05-11 17:45 | yorik | Note Added: 0004650 | |
| 2014-05-11 17:45 | yorik | Status | assigned => closed |
| 2014-05-11 17:45 | yorik | Resolution | open => fixed |
| 2014-05-11 17:45 | yorik | Fixed in Version | => 0.14 |
| 2014-05-11 17:45 | yorik | Relationship deleted | parent of 0000853 |
| 2014-05-11 17:45 | yorik | Relationship added | child of 0000853 |
