| 0001412 | PartDesign | Bug | public | 2014-02-13 23:48 | 2014-03-12 17:59 |
| Reporter | stth | Assigned To | wmayer | ||
| Platform | linux | OS | ubuntu | OS Version | 13.10 |
| Summary | 0001412: Extrunding sketch doesn't make a solid | ||||
| Description | the uploaded sketch cannot be extruded to a solid although the solver says, the sketch would be ok. extruding a rectangle using the same steps works fine. | ||||
| Steps To Reproduce | new file workbench partdesign new sketch yz-plane, tick inverse (does not seem to matter) reproduce the sketch workbench part extrude to negative x-axis (-1,0,0), tick make solid voila, front and back are missing | ||||
| Additional Information | freecad is from installed via apt from universe (0.13.1830-dfsg-3) | ||||
after changing solid to false and back to true again, the shape get recomputed. It then become a solid in my version. OS: Debian GNU/Linux 7.4 (wheezy) Platform: 64-bit Version: 0.14.3140 (Git) Branch: piecewise-bezier Hash: d658bc6851a2611bd08b1c4a9aee1fc38628cc9a Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.7.0 Instead of using Part/Extrude you should use PartDesign/Pad as it assumes that you always want to create a solid. BTW: You did not provide complete FreeCAD version information |
Using the old 0.13.1828 build on Windows shows the same behaviour that the solid fails -- but the pad works. This version uses OCC 6.3. Using OCC 6.6 in a newer version works. So, to solve this issue for older OCC versions we can move the extra checks we do for the pad to the extrude function. |
ok, pad works in my version, too, thanks |
I reckon this can be closed? Please reopen if it should stay open |
The extrude feature should be ironed a bit so that it works as reliably as the pad. Also if the solid option is checked it should support faces with holes. |
| 2014-02-13 23:48 | stth | New Issue | |
| 2014-02-13 23:48 | stth | File Added: extrude_bug.FCStd | |
| 2014-02-14 08:19 | shoogen | Note Added: 0004218 | |
| 2014-02-14 08:37 | wmayer | Note Added: 0004219 | |
| 2014-02-14 18:46 | stth | Note Added: 0004222 | |
| 2014-03-11 01:47 | yorik | Note Added: 0004412 | |
| 2014-03-11 01:47 | yorik | Status | new => closed |
| 2014-03-11 01:47 | yorik | Resolution | open => no change required |
| 2014-03-11 01:47 | yorik | Fixed in Version | => 0.14 |
| 2014-03-11 08:42 | wmayer | Note Added: 0004421 | |
| 2014-03-11 08:42 | wmayer | Assigned To | => wmayer |
| 2014-03-11 08:42 | wmayer | Severity | major => minor |
| 2014-03-11 08:42 | wmayer | Status | closed => assigned |
| 2014-03-11 08:42 | wmayer | Resolution | no change required => reopened |
| 2014-03-12 17:59 | wmayer | Changeset attached | => FreeCAD Master master f96fbcac |
| 2014-03-12 17:59 | wmayer | Status | assigned => closed |
