0001414FreeCADBugpublic2014-02-21 16:00
Reporterquick61 Assigned Toyorik
Status closedResolutionfixed
Product Versiontrunk
Summary0001414: Use new properties API in Draft & Arch
DescriptionReference forum threads -
http://forum.freecad.org/viewtopic.php?f=8&t=5708&p=46235#p46235
http://forum.freecad.org/viewtopic.php?f=3&t=5709
Use of Draft Dimension causing "signal SIGABRT, Aborted." crash
Steps To ReproduceTo replicate, make a box or any shape that can be measured with Draft Dimension tool. Pick 2 points to measure between. Drag dimension line to desired location. Click mouse to finish opperation and hard crash occurs.
Additional InformationSee Forum postings for console output and backtrace.
TagsQuantity
ulrich1a
2014-02-18 21:21
reporter
Draft.patch (Attachment missing)
ulrich1a
2014-02-18 21:23
reporter   ~0004235
I put a .Value at those properties, which are effected from the Quantity change. If fixes the problem for me. See file Draft.patch
Ulrich
quick61
2014-02-19 00:09
reporter   ~0004236
I manually edited Draft.py with the changes in the patch file sense I couldn't figure out how to make patch work on my local directory.
For me, that stopped the crashing, and Draft Dimension seems to now be working again. However, I'm getting errors out on the console. -
Draft workbench activated
Pick first point:
  File "/home/mark/Build/FreeCAD/Mod/Draft/Draft.py", line 3013, in attach
    self.onChanged(vobj,"FontSize")
  File "/home/mark/Build/FreeCAD/Mod/Draft/Draft.py", line 3161, in onChanged
    self.font3d.size = vobj.FontSize*100
  File "/usr/lib/python2.7/dist-packages/pivy/coin.py", line 3795, in __setattr__
    field.setValue(value)
  File "/usr/lib/python2.7/dist-packages/pivy/coin.py", line 5294, in setValue
    return _coin.SoSFFloat_setValue(self, *args)
<type 'exceptions.NotImplementedError'>: Wrong number or type of arguments for overloaded function 'SoSFFloat_setValue'.
  Possible C/C++ prototypes are:
    SoSFFloat::setValue(float)
    SoSFFloat::setValue(SoSFFloat const *)
yorik
2014-02-20 15:29
administrator   ~0004252
This problem affects not only dimensions bu all Draft & Arch objects and is caused by a change in the properties API ( http://forum.freecad.org/viewtopic.php?f=10&t=5741 ). I'll change the name of this ticket and adapt all the objects at once...
yorik
2014-02-21 15:38
administrator   ~0004258
Ok this should be fixed across Draft & Arch now, unless I missed something...
Related Changesets
FreeCAD: master a63f4c1f
2014-02-21 16:37:29
yorik
Details Diff
Used new PropertyQuantity API in Draft & Arch - fixes 0001414 Affected Issues
0001414
mod - src/Mod/Arch/ArchAxis.py Diff File
mod - src/Mod/Arch/ArchComponent.py Diff File
mod - src/Mod/Arch/ArchFloor.py Diff File
mod - src/Mod/Arch/ArchFrame.py Diff File
mod - src/Mod/Arch/ArchRebar.py Diff File
mod - src/Mod/Arch/ArchRoof.py Diff File
mod - src/Mod/Arch/ArchSectionPlane.py Diff File
mod - src/Mod/Arch/ArchSite.py Diff File
mod - src/Mod/Arch/ArchSpace.py Diff File
mod - src/Mod/Arch/ArchStairs.py Diff File
mod - src/Mod/Arch/ArchStructure.py Diff File
mod - src/Mod/Arch/ArchWall.py Diff File
mod - src/Mod/Arch/ArchWindow.py Diff File
mod - src/Mod/Arch/TestArch.py Diff File
mod - src/Mod/Draft/Draft.py Diff File
2014-02-15 19:16 quick61 New Issue
2014-02-15 19:30 shoogen Tag Attached: Quantity
2014-02-18 21:21 ulrich1a File Added: Draft.patch
2014-02-18 21:23 ulrich1a Note Added: 0004235
2014-02-19 00:09 quick61 Note Added: 0004236
2014-02-19 00:12 quick61 Note Edited: 0004236
2014-02-20 15:29 yorik Note Added: 0004252
2014-02-20 15:29 yorik Assigned To => yorik
2014-02-20 15:29 yorik Status new => assigned
2014-02-20 15:30 yorik Summary Draft Dimension Causing Crash => Use new properties API in Draft & Arch (was: Draft Dimension Causing Crash)
2014-02-20 15:31 yorik Summary Use new properties API in Draft & Arch (was: Draft Dimension Causing Crash) => Use new properties API in Draft & Arch
2014-02-21 15:38 yorik Note Added: 0004258
2014-02-21 16:00 yorik Changeset attached => FreeCAD Master master a63f4c1f
2014-02-21 16:00 yorik Status assigned => closed
2014-02-21 16:00 yorik Resolution open => fixed
