0001425FreeCADBugpublic2014-02-22 02:24
Reportervkrastev Assigned To
Status closedResolutionfixed
PlatformLinuxOSUbuntuOS Version12.04 LTS
Product Version0.13
Summary0001425: Error in the package update
DescriptionToday (20/02/2014) I was trying to update the freecad package, but the terminal response after doing sudo apt-get update and sudo apt-get upgrade was the following:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages have been kept back:
  freecad
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Instead, trying to reinstall the package with sudo apt-get install freecad produced:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 freecad : Depends: liboce-foundation8 but it is not installable
           Depends: liboce-modeling8 but it is not installable
           Depends: liboce-ocaf-lite8 but it is not installable
           Depends: liboce-ocaf8 but it is not installable
           Depends: liboce-visualization8 but it is not installable
E: Unable to correct problems, you have held broken packages.
The strange thing is that previous updates went without a problem, so I cannot whether the problem actually is.
Steps To ReproduceI don't know if it can be reproduced on other distros or even other machines.
ickby
2014-02-20 12:45
developer   ~0004250
http://forum.freecadweb.org/viewtopic.php?f=4&t=5888
vkrastev
2014-02-20 15:54
reporter   ~0004253
Ok, thanks, I will do the required updates.
normandc
2014-02-22 02:24
manager   ~0004262
Closing this report as the solution was given.
2014-02-20 10:32 vkrastev New Issue
2014-02-20 12:45 ickby Note Added: 0004250
2014-02-20 15:54 vkrastev Note Added: 0004253
2014-02-22 02:24 normandc Note Added: 0004262
2014-02-22 02:24 normandc Status new => closed
2014-02-22 02:24 normandc Resolution open => fixed
