| 0001436 | Sketcher | Feature | public | 2014-02-23 18:03 | 2021-05-25 10:42 |
| Reporter | bejant | Assigned To | abdullah | ||
| Summary | 0001436: Sketcher: Break a Line and Add a Point onto a Line | ||||
| Description | A forum user requested two new features which seem useful: 1. Break a line into two segments, leaving a gap where the user clicked between the two new segments. I'll add that the default gap should be user selectable. 2. Add a point onto a line. From the following forum thread: http://forum.freecadweb.org/viewtopic.php?f=8&t=5928#p47176 | ||||
| Additional Information | Feature request #1 reminds me of a little lisp routine named brk.lsp that I used to use daily in AutoCAD. I did a web search and believe the following code is the proper routine, maybe it will be of help (or maybe not). (defun c:brk(/ os pt1 pt2) (setvar "CMDECHO" 0) (setq os (getvar "osmode")) (setvar "osmode" 512) (setq pt1 (getpoint "\nPick object to be broken : ")) (setvar "osmode" 33) (setq pt2 (getpoint "\nBreak point : ")) (setvar "osmode" 0) (command "break" pt1 "f" pt2 "@") (setvar "osmode" os) (princ) ) | ||||
| 2014-02-23 18:03 | bejant | New Issue | |
| 2015-09-10 13:13 | abdullah | Assigned To | => abdullah |
| 2015-09-10 13:13 | abdullah | Status | new => assigned |
| 2018-10-06 15:13 | abdullah | Target Version | => 0.19 |
| 2021-02-06 05:55 | abdullah | Target Version | => 0.20 |
| 2021-05-25 10:42 | aviket | Note Added: 0015677 |
