| 0001439 | Draft | Feature | public | 2014-02-24 10:14 | 2014-02-24 18:02 |
| Reporter | shoogen | Assigned To | yorik | ||
| Summary | 0001439: use DistShapeShape in DraftGeomUtils.findIntersection | ||||
| Description | use DistShapeShape in DraftGeomUtils.findIntersection | ||||
| parent of | 0001373 | closed | FreeCAD | Expose BRepExtrema_DistShapeShape to python |
currently findIntersection doesn't know the courser position, which would be helpful to find wich solution to choose. |
ah yes, we talked about that already... I'll have a look |
Amazing! it works very well... Draft snapping works much, much better and supports any curve type now. |
maybe you should check that dist is below a threshold. |
The draft snapping system does that already... Besides, it doesn't take all objects into account, but only the last two over which the mouse was hovered, so it is quite efficient. |
| 2014-02-24 10:14 | shoogen | New Issue | |
| 2014-02-24 10:16 | shoogen | Relationship added | parent of 0001373 |
| 2014-02-24 10:44 | shoogen | Note Added: 0004285 | |
| 2014-02-24 13:11 | yorik | Note Added: 0004286 | |
| 2014-02-24 13:11 | yorik | Assigned To | => yorik |
| 2014-02-24 13:11 | yorik | Status | new => assigned |
| 2014-02-24 15:19 | yorik | Note Added: 0004290 | |
| 2014-02-24 17:42 | shoogen | Note Added: 0004295 | |
| 2014-02-24 18:00 | yorik | Changeset attached | => FreeCAD Master master bab0c366 |
| 2014-02-24 18:02 | yorik | Note Added: 0004296 | |
| 2014-02-24 18:02 | yorik | Status | assigned => closed |
| 2014-02-24 18:02 | yorik | Resolution | open => fixed |
| 2014-02-24 18:02 | yorik | Fixed in Version | => 0.14 |
