| 0000144 | FreeCAD | Feature | public | 2010-08-27 15:00 | 2012-06-09 12:01 |
| Reporter | normandc | Assigned To | |||
| Summary | 0000144: Add several tools to Part module | ||||
| Description | in the Part module : add sweep and loft graphical tools, add chamfer tool | ||||
This goes directly into PartDesign. Part sould be a place for the rather low level things about the CAD data structure. The higher level methodes should be located in PartDesign (for Solid stuff) and ShapeDesign (for open survaces). But never the less - needed tools! |
I see that r3879 now has chamfer tool (probably added a long time ago), so this feature request is 1/3 completed. :-P Maybe we should make separate entries, one each for loft, sweep and chamfer so we could close the chamfer one? |
2/3 completed. r5028 adds a loft utility. |
See also: http://forum.freecad.org/viewtopic.php?f=8&t=2315 |
Taken from 0000395: Make a user interface for pipe, pipe shell and loft functions |
We discussed variable section sweep http://forum.freecad.org/viewtopic.php?f=10&t=2573&start=10 makePipeShell is able to handle many different sections and sweep them along path. Graphics tool implementation would look similar to Part Loft tool. |
git 245cae0 adds a sweep utility which internally uses the makePipeShell function |
git show 2a7e6f3 |
| 2010-08-27 15:00 | wmayer | New Issue | |
| 2010-08-27 15:00 | wmayer | Reporter | wmayer => normandc |
| 2010-09-01 07:29 |
Note Added: 0000313 | |
| 2010-09-01 07:30 |
Status | new => assigned |
| 2010-09-01 07:30 |
Assigned To | => Jriegel |
| 2011-01-13 22:31 | normandc | Note Added: 0000516 | |
| 2011-02-22 12:03 |
Relationship added | child of 0000277 |
| 2011-10-15 11:34 | wmayer | Note Added: 0001159 | |
| 2012-03-02 08:42 | wmayer | Note Added: 0001699 | |
| 2012-03-02 08:43 | wmayer | Relationship added | related to 0000395 |
| 2012-03-02 08:44 | wmayer | Note Added: 0001700 | |
| 2012-05-24 15:30 | kwahooo | Note Added: 0002081 | |
| 2012-05-24 15:35 | kwahooo | Note Edited: 0002081 | |
| 2012-06-09 09:51 | wmayer | Note Added: 0002165 | |
| 2012-06-09 12:01 | wmayer | Note Added: 0002166 | |
| 2012-06-09 12:01 | wmayer | Status | assigned => closed |
| 2012-06-09 12:01 | wmayer | Resolution | open => fixed |
| 2012-06-09 12:01 | wmayer | Fixed in Version | => 0.13 |
