0001444DraftBugpublic2014-05-03 15:46
ReporterjohnD Assigned Toyorik
PlatformUbuntuOSLinuxOS Version13.10
Product Version0.13
Fixed in Version0.14
Summary0001444: Bombs out Using Draft Workbench
DescriptionWhen trying to draw shapes in draft the application crashes without warning or any error messages.
Steps To ReproduceSelect draft Workspace
Select line and draw
Select DWire and draw
Select circle pointer does not change to cross and impossible to draw
Select octagon, same as for circle
Select dimension application crashes without warning or error messages
Additional InformationInformation taken from the About information:
OS: Ubuntu 13.10
Platform: 32-bit
Version: 0.13.1830 (Git)
Branch: releases/FreeCAD-0-13
Hash: ec7636d7aaf2612e9b43cff5d6a424037d53e505
Python version: 2.7.5+
Qt version: 4.8.4
SoQt version: 1.5.0
OCC version: 6.5.4
quick61
2014-02-25 19:11
reporter   ~0004304
johnD, the version you are using is very old and I would recommend you install a current 0.14 version from the PPA.
You should see this post on the forums for instructions on how to install it.
http://forum.freecadweb.org/viewtopic.php?f=4&t=5888
As I type, there have been over thirteen hundred and eighty bug fixes/additions/improvements to FreeCAD sense the version you have installed now. (0.13.1830)
I'm sure that whatever issues you are experiencing have long sense been fixed and included in the current 0.14 development builds available through the PPA.
yorik
2014-03-27 21:01
administrator   ~0004502
I'll assing this to myself and close it if we don't get more feedback... Indeed it doesn't cause any crash for me, probably something already solved.
yorik
2014-05-03 15:46
administrator   ~0004610
I'll close this report since the bug is fixed in the current code.
2014-02-25 18:17 johnD New Issue
2014-02-25 19:11 quick61 Note Added: 0004304
2014-02-25 19:13 quick61 Note Edited: 0004304
2014-03-27 21:01 yorik Note Added: 0004502
2014-03-27 21:01 yorik Assigned To => yorik
2014-03-27 21:01 yorik Status new => feedback
2014-03-29 19:50 yorik Project FreeCAD => Draft
2014-05-03 15:46 yorik Note Added: 0004610
2014-05-03 15:46 yorik Status feedback => closed
2014-05-03 15:46 yorik Resolution open => no change required
2014-05-03 15:46 yorik Fixed in Version => 0.14
