0001450FreeCADBugpublic2015-07-02 12:49
Reportertanderson69 Assigned Totanderson69
Status closedResolutionfixed
Platformamd64OSKubuntuOS Version 13.10
Product Versiontrunk
Fixed in Version0.16
Summary0001450: model refine corrupts solid with spherical edges.
DescriptionBRepLib_FuseEdges corrupts topology with spherical edges.
Steps To Reproducehttp://forum.freecad.org/viewtopic.php?f=10&t=2389&start=100#p47482
Additional InformationI think we can work around this problem. Somebody can assign this bug too me or give me the permissions to do it.
tanderson69
2014-02-28 22:07
developer   ~0004335
fix is on the sourceforge branch tanderson-merge-partCheckGeometry
git cherry-pick 2f5d8230f933388517e63c15fee9091e98921a1b
2014-03-01 12:16
administrator   ~0004338
git show 7d853e3
tanderson69
2014-03-03 02:17
developer   ~0004358
the breplib_fuseedge bug affects goes beyond spherical edges. see http://forum.freecad.org/viewtopic.php?f=10&t=2389&start=100#p47653 for an example.
modified code to avoid all geom_conics for edges.
//assuming origin is sourceforge
git fetch origin cb3b129af877c83b4717d2cee44befe6d0cb58be && git cherry-pick cb3b129af877c83b4717d2cee44befe6d0cb58be
shoogen
2014-03-03 08:52
developer   ~0004360
tanderson:
by using "cherry-pick --ff" you get a fast forward merge if possible.
2014-03-03 09:34
administrator   ~0004361
git show 4f6b64f
shoogen
2014-12-11 23:54
developer   ~0005369
// TODO: change this version after occ fix. Freecad Mantis 1450
#if OCC_VERSION_HEX <= 0x070000
AFAIK the problem is not scheduled for 7.0.0
http://tracker.dev.opencascade.org/view.php?id=24692
tanderson69
2014-12-12 13:46
developer   ~0005370
I put the directive there as more of a place holder. We can just increase the number or comment out directive completely for now.
shoogen
2014-12-12 17:58
developer   ~0005371
I'd suggest to increase the number to something large like 0x7f0000
to indicate that the fix is not yet available
tanderson69
2015-07-01 18:51
developer   ~0006239
looking at the code for "OCC version: 6.8.0.oce-0.17-dev": calling BrepLib_FuseEdges::Perform directly has a different execution path than calling it indirectly through BrepLib_FuseEdges::Faces. Removing the Perform call gets desired results.
Related Changesets
FreeCAD: master fe4ab358
2015-01-08 08:56:09
shoogen
Committer: yorik Details Diff
issue 0001450 Affected Issues
0001450
mod - src/Mod/Part/App/modelRefine.cpp Diff File
2014-02-27 18:42 tanderson69 New Issue
2014-02-27 22:43 wmayer Assigned To => tanderson69
2014-02-27 22:43 wmayer Status new => assigned
2014-02-28 22:07 tanderson69 Note Added: 0004335
2014-03-01 12:16 wmayer Note Added: 0004338
2014-03-01 12:16 wmayer Status assigned => closed
2014-03-01 12:16 wmayer Resolution open => fixed
2014-03-01 12:16 wmayer Fixed in Version => 0.14
2014-03-03 02:17 tanderson69 Note Added: 0004358
2014-03-03 02:17 tanderson69 Status closed => feedback
2014-03-03 02:17 tanderson69 Resolution fixed => reopened
2014-03-03 08:52 shoogen Note Added: 0004360
2014-03-03 09:34 wmayer Note Added: 0004361
2014-03-03 09:35 wmayer Status feedback => closed
2014-03-03 09:35 wmayer Resolution reopened => fixed
2014-12-11 23:54 shoogen Note Added: 0005369
2014-12-11 23:54 shoogen Status closed => feedback
2014-12-11 23:54 shoogen Resolution fixed => reopened
2014-12-11 23:56 shoogen Note Edited: 0005369
2014-12-12 13:46 tanderson69 Note Added: 0005370
2014-12-12 13:46 tanderson69 Status feedback => assigned
2014-12-12 17:58 shoogen Note Added: 0005371
2015-01-10 14:40 yorik Changeset attached => FreeCAD Master master fe4ab358
2015-07-01 18:51 tanderson69 Note Added: 0006239
2015-07-02 12:49 wmayer Status assigned => closed
2015-07-02 12:49 wmayer Resolution reopened => fixed
2015-07-02 12:49 wmayer Fixed in Version 0.14 => 0.16
