| 0001452 | FreeCAD | Bug | public | 2014-02-28 09:17 | 2014-02-28 09:39 |
| Reporter | shoogen | Assigned To | shoogen | ||
| Summary | 0001452: JSON serialisation fails | ||||
| Description | JSON serialisation fails for objects neither implemention __getstate__ nor __dict__ in src/App/PropertyPythonObject.cpp:100 the plain object is passed to json.dump but the exeception is not catched. | ||||
In App::PropertyPythonObject::fromString(std::string const&) the ValueError in json.loads in the first try block prevents the ViewProvider to be attached. |
git show 849e39f |
the ticket wasn't about the involute gear failing. It was about every ViewProvider failing which doesn't implement __setstate__ the commit did not fix that issue |
| 2014-02-28 09:17 | shoogen | New Issue | |
| 2014-02-28 09:18 | shoogen | Description Updated | |
| 2014-02-28 09:24 | shoogen | Note Added: 0004328 | |
| 2014-02-28 09:26 | shoogen | Status | new => closed |
| 2014-02-28 09:26 | shoogen | Assigned To | => wmayer |
| 2014-02-28 09:26 | shoogen | Resolution | open => fixed |
| 2014-02-28 09:26 | shoogen | Fixed in Version | => 0.14 |
| 2014-02-28 09:29 | shoogen | Assigned To | wmayer => |
| 2014-02-28 09:29 | shoogen | Status | closed => feedback |
| 2014-02-28 09:29 | shoogen | Resolution | fixed => reopened |
| 2014-02-28 09:30 | shoogen | Assigned To | => shoogen |
| 2014-02-28 09:30 | shoogen | Status | feedback => new |
| 2014-02-28 09:30 | shoogen | Assigned To | shoogen => |
| 2014-02-28 09:31 | shoogen | Steps to Reproduce Updated | |
| 2014-02-28 09:32 | wmayer | Note Added: 0004330 | |
| 2014-02-28 09:32 | wmayer | Status | new => closed |
| 2014-02-28 09:32 | wmayer | Resolution | reopened => fixed |
| 2014-02-28 09:39 | shoogen | Assigned To | => shoogen |
| 2014-02-28 09:39 | shoogen | Note Added: 0004331 | |
| 2014-02-28 09:39 | shoogen | Status | closed => feedback |
| 2014-02-28 09:39 | shoogen | Resolution | fixed => reopened |
| 2014-02-28 09:39 | shoogen | Status | feedback => closed |
| 2014-02-28 09:39 | shoogen | Resolution | reopened => won't fix |
| 2014-02-28 09:39 | shoogen | Resolution | won't fix => reopened |
| 2014-02-28 09:39 | shoogen | Fixed in Version | 0.14 => |
