| 0001463 | FreeCAD | Bug | public | 2014-03-06 07:58 | 2014-03-08 09:38 |
| Reporter | shoogen | Assigned To | wmayer | ||
| Summary | 0001463: setting Vertex.Tolerance modifies bound and shared shapes | ||||
| Description | It it possible to change the Vertex Tolerance on a bound shape. It is not possible to work on a Copy as the change affects the original Shape as well. It seems that the copy-on-write is not properly implemented. | ||||
| Steps To Reproduce | >>> s1=Part.makeBox(5,4,3) >>> s2=s1.copy() >>> for v in s2.Vertexes: ... v.Tolerance=0.5 ... >>> [v.Tolerance for v in s2.Vertexes] [0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5] >>> [v.Tolerance for v in s1.Vertexes] [0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5] >>> | ||||
| Additional Information | note on severity: given the fact that the problem is breaks the copy-on-write i would consider it to by mayor or even blocker. given the fact that nobody messes with the Tolerance yet, it is minor. | ||||
| 2014-03-06 07:58 | shoogen | New Issue | |
| 2014-03-06 07:59 | shoogen | Summary | setting Vertex.Tolerance modifies bound and shares shapes => setting Vertex.Tolerance modifies bound and shared shapes |
| 2014-03-06 09:09 | wmayer | Changeset attached | => FreeCAD Master master 92253429 |
| 2014-03-06 09:09 | wmayer | Assigned To | => wmayer |
| 2014-03-06 09:09 | wmayer | Status | new => closed |
| 2014-03-06 09:09 | wmayer | Resolution | open => fixed |
| 2014-03-08 09:38 | wmayer | Relationship added | related to 0001465 |
