0001466DraftFeaturepublic2014-03-29 15:09
Reporterjmaustpc Assigned Toyorik
PrioritynormalSeverityfeatureReproducibilityalways
Platformall
Product Versiontrunk
Target Versiontrunk
Summary0001466: Allow Draft Arc object to be joined into a wire or face with Draft Upgrade
DescriptionIf a Draft Arc is one of the components in a multi selection of Draft objects which describe a perimeter of an object, Draft Upgrade will fail and output an error message "can not upgrade objects".
In other words you can not upgrade a closed set of Dlines/Lines/Dwires etc. that includes a D_Arc, into a wire or face.
There is an example of a DXF file in this topic on the forum
http://forum.freecadweb.org/viewtopic.php?f=3&t=6028#p47962
Is it possible to allow the inclusion of D-Arcs?
yorik
2014-03-09 21:30
administrator   ~0004401
groups of edges containing arcs can be upgraded to wires and faces, not up to draft wires (which are defined by points, so they cannot have arc segments).
I just tested here, all seems to work normally for me...
jmaustpc
2014-03-29 15:06
manager   ~0004513
I still have the problem with and that file from the post so I have experimented some more.
OS: Ubuntu 12.04.4 LTS
Platform: 64-bit
Version: 0.14.3369 (Git)
Hash: 8693bfab1abc0ba4191d30ab50f8c465bbb920a3
Python version: 2.7.3
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
I edited the Draft Line edge adjacent to the Draft Arc and snapped it to the end of the Draft Arc, then when I select the edge and arc they will upgrade to a joined wire.
My conclusion is that it was a precision matter all along .....sorry to waste your time.
So I have closed this.
Jim
jmaustpc
2014-03-29 15:09
manager   ~0004514
It appears that I was wrong, this upgrade failed due to precision, the edge did not quite end on the end of the arc. It was not failing just because the Arc was included in the perimeter.
2014-03-09 13:50 jmaustpc New Issue
2014-03-09 13:50 jmaustpc Status new => assigned
2014-03-09 13:50 jmaustpc Assigned To => yorik
2014-03-09 21:30 yorik Note Added: 0004401
2014-03-11 01:26 yorik Project FreeCAD => Draft
2014-03-12 14:45 yorik Status assigned => feedback
2014-03-29 15:06 jmaustpc Note Added: 0004513
2014-03-29 15:06 jmaustpc Status feedback => assigned
2014-03-29 15:09 jmaustpc Note Added: 0004514
2014-03-29 15:09 jmaustpc Status assigned => closed
2014-03-29 15:09 jmaustpc Resolution open => no change required
