0001467PartDesignBugpublic2014-04-25 10:58
ReporterAngeliccare Assigned Towandererfan
PlatformAMD x64OSWindows 7 64, 16Gb RAM
Product Version0.13
Summary0001467: Wierd functioning of Part.translate for micro distances
DescriptionRun macro on the empty document. Macro version with
                support.translate((+xoffset,+yoffset,0.1)) #
                support1.translate((+xoffset,+yoffset,0.1)) #
                support=support.cut(shape1)
                support1=support1.cut(shape1)
                support.translate((-xoffset,-yoffset,0.1)) #
                support1.translate((-xoffset,-yoffset,0.1)) #
works (however gives production precision error in forming support), but
                support.translate((+xoffset,+yoffset,0.00001)) #
                support1.translate((+xoffset,+yoffset,0.00001)) #
                support.translate((-xoffset,-yoffset,0.00001)) #
                support1.translate((-xoffset,-yoffset,0.00001)) #
crashes the FreeCAD after some minutes of work. wha da?
Steps To ReproduceRun this:
import FreeCAD,Part,math
class Lego:
    '''return a lego brick'''
    def __init__(self,obj, unitsX=4, unitsY=2,unitsZ=1,modifier=0):
        obj.addProperty("App::PropertyInteger","unitsX","Lego","Size in knobs in X direction.").unitsX = unitsX
        obj.addProperty("App::PropertyInteger","unitsY","Lego","Size in knobs in Y direction.").unitsY = unitsY
        obj.addProperty("App::PropertyInteger","unitsZ","Lego","Size in knobs in Z direction.").unitsZ = unitsZ
        obj.addProperty("App::PropertyInteger","modifier","Lego","Variant No ").modifier = modifier
        obj.Proxy = self
    def onChanged(self, fp, prop):
        "Do something when a property has changed"
        pass
    def execute(self, fp):
        fp.Shape=Lego.buildshape(fp.unitsX, fp.unitsY, fp.unitsZ,fp.modifier)
    @staticmethod
    def buildshape(unitsX, unitsY,unitsZ,modifier):
        gap=0.1
        gaps=2*gap
        unitSize = 8
        height=9.6
        knobHeight=1.8
        knobRadius=4.8/2
        wall=1.5
        upWall=5.5 #// guessed
        supportthickness=0.6 # 0.15x4 or 0.20x3
        maxsupportlayerthickness=0.15
        supportdistance=4 # 4x4=16mm^2, printer option
        cylRadius = (unitSize*math.sqrt(2)-2*knobRadius)/2 0000003,2568542494923801952067548968388
        cylWall = round(3.25685,5)
        l=unitSize*unitsX-gaps
        w= unitSize*unitsY-gaps
        c1=Part.makeBox(l, w, height,FreeCAD.Vector(-l/2.0,-w/2.0,0))
        c2=Part.makeBox(l-gaps-2*wall, w-gaps-2*wall, height,FreeCAD.Vector(-(l-gaps-2*wall)/2.0,-(w-gaps-2*wall)/2.0,-1*upWall))
        d1=c1.cut(c2)
        shape1=d1 # box
        knobs=Part.Shape()
# shape1=Part.Shape()#makeBox(1,1,1)
        knob=Part.makeCylinder(knobRadius,knobHeight+upWall/2,FreeCAD.Vector(0,0,height-upWall/2.0))
        for x in range(unitsX):
            for y in range(unitsY):
                newknob=knob.copy()
                newknob.translate((x*unitSize, y*unitSize, 0))
                if knobs.isNull():
                    knobs=newknob
                else:
                    knobs=knobs.fuse(newknob)
        knobs.translate(((1-unitsX)*unitSize/2, (1-unitsY)*unitSize/2, 0))
        if (unitsX > 1 and unitsY > 1)or(modifier==-1):
            cyl=Part.makeCylinder(cylRadius,height-upWall/2 ).cut(Part.makeCylinder(cylRadius-cylWall,height))
            cyl.translate((0,0,upWall/8))
            cyls=Part.Shape()
            for x in range(unitsX-1):
                for y in range(unitsY-1):
                    newcyl=cyl.copy()
                    newcyl.translate((x*unitSize, y*unitSize, 0))
                    if cyls.isNull():
                        cyls=newcyl
                    else:
                        cyls=cyls.fuse(newcyl)
            cyls.translate(((2-unitsX)*unitSize/2, (2-unitsY)*unitSize/2, 0))
            if modifier==2: #
                newknobs=knobs.copy() #
                newknobs.translate((0,0,height*unitsZ-height)) #
                shape1=shape1.fuse(newknobs) #
# return shape1 #
            for x in my_range(1,unitsX,2):
                 zmodifier=0
                 if modifier<=0:
                     zmodifier=0
                 else:
                     zmodifier=1
                 carrycy =Part.makeCylinder(unitSize/2,height*unitsZ-height ) # height+ # *(1-zmodifier)
                 carrycy.translate((unitSize*unitsX/2-x*unitSize,-unitSize/2-wall,height))
                 wallnearwallbase=Part.makeBox(l, w, height,FreeCAD.Vector(-l/2.0,-w/2.0+unitSize*unitsY,0)) #-wall*(1-zmodifier)
                 wallnearwall=Part.makeBox(l-gaps-2*wall, w-gaps-2*wall, height,FreeCAD.Vector(-(l-gaps-2*wall)/2.0,-(w-gaps-2*wall)/2.0+unitSize*unitsY,-1*upWall))
                 shape1=shape1.fuse(carrycy) # carry cylynder
                 wallnearwallbase=wallnearwallbase.cut(wallnearwall)#knobs=knobs.cut(wallnearwall)
                 wallnearwallbase.translate((0,-unitSize*unitsY,height*unitsZ-height))
                 if zmodifier==0:
                     shape1=shape1.cut(wallnearwallbase)#knobs=knobs.cut(wallnearwall)
                 else:
                     shape1=shape1.fuse(wallnearwallbase)#knobs=knobs.cut(wallnearwall)
# else:
            c1_=Part.makeBox(l, wall, height*unitsZ,FreeCAD.Vector(-l/2.0,-w/2.0-wall*2,0))
            c2_=Part.makeBox(l, wall, height,FreeCAD.Vector(-l/2.0,-w/2.0-wall,0))
            shape1=shape1.fuse(c2_) # side panel base
            shape1=shape1.fuse(c1_) # side panel
#.fuse(c1_)
            shape1=shape1.fuse(knobs)#
            shape1=shape1.fuse(cyls)#.removeSplitter() #
# shape=shape.fuse(shape1)
# shape=knobs.fuse(d1).removeSplitter()
        else:
            shape1=knobs.fuse(d1).removeSplitter()
        #Part.show(d1.common(cyls))
        for x in my_range(1,unitsX*unitSize,supportdistance): #
            origvector=FreeCAD.Vector(-l/2.0+x,-w/2.0-1,-2*supportthickness)
            support=Part.makeBox(supportthickness,w+2,height-upWall-maxsupportlayerthickness+2*supportthickness,origvector)
            support1=Part.makeBox(supportthickness/2,w+2,height-upWall+2*supportthickness,origvector)
            xoffset=0
            yoffset=0
            for ttranslation in range(1,9): # [1,2,3,4,5,6,7,8]
                if ttranslation==1:
                    xoffset=0
                    yoffset=1
                elif ttranslation==2:
                    xoffset=1
                    yoffset=0
                elif ttranslation==3:
                    xoffset=1
                    yoffset=1
                elif ttranslation==4:
                    xoffset=-1
                    yoffset=1
                elif ttranslation==5:
                    xoffset=-1
                    yoffset=-1
                elif ttranslation==6:
                    xoffset=-1
                    yoffset=0
                elif ttranslation==7:
                    xoffset=0
                    yoffset=-1
                elif ttranslation==8:
                    xoffset=1
                    yoffset=-1
# elif ttranslation==2:
# xoffset=1
# xoffset=1
            shape1=shape1.fuse(support)
            shape1=shape1.fuse(support1)
        return shape1
def my_range(start, end, step):
    while start <= end:
        yield start
        start += step
def makeLego(x,y,z,modifier,doc=None):
    doc = doc or FreeCAD.ActiveDocument
    obj=doc.addObject("Part::FeaturePython","Lego")
    Lego(obj)
    obj.unitsX=x
    obj.unitsY=y
    obj.unitsZ=z
    obj.modifier=modifier
    obj.ViewObject.Proxy=0 # just set it to something different from None (this assignment is needed to run an internal notification)
    return obj
if __name__ == '__main__':
    #nonparametric
    #Part.show(Lego.buildshape(4,2))
    #parametric
# modifier -1 - mono rail
# modifier 0 - -1 wall
# modifier 1 - full mono wall, upper solid
    makeLego(8,2,6,2)
# makeLego(8,2)
# makeLego(16,2)
Angeliccare
2014-03-09 16:30
reporter   ~0004398
Forgot to mention: Tried on 13stable.
2014-03-15 12:46
administrator   ~0004449
The macro doesn't work (syntax error):
wandererfan
2014-03-19 16:30
manager   ~0004477
with the syntax error fixed, this works under:
OS: Ubuntu 12.04.4 LTS
Platform: 64-bit
Version: 0.14.3327 (Git)
Branch: FT2dGeom
Hash: 0bff92a4393d9974a974f95e4326a2f4ca823719
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
** Debug build **
But hangs in line 139: support1=support1.cut(shape1) under:
Platform: 64-bit
Version: 0.14.3269 (Git)
Hash: c535b2d330dd876b610ee51047170cf3722d5756
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.1
** Release build
I going to recompile my Master version with OCC 6.7.0 to see if that's the problem. Win builds use an older OCC, correct?
wandererfan
2014-03-20 19:48
manager
wandererfan
2014-03-20 19:55
manager   ~0004482
this also works here:
Platform: 64-bit
Version: 0.14.3326 (Git)
Hash: e6bd7e8de3527366c35254739c25a05781f92ab0
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0 <---
** Release build
So I'm guess it is an issue of OCC version not being the latest. If the OCC in the Win libpack is up to date, it should work in v0.14.
wandererfan
2014-04-25 10:58
manager   ~0004574
upgraded OCC version fixes problem.
2014-03-09 16:23 Angeliccare New Issue
2014-03-09 16:30 Angeliccare Note Added: 0004398
2014-03-09 16:37 wmayer Severity crash => major
2014-03-09 16:37 wmayer Product Version => 0.13
2014-03-15 12:46 wmayer Note Added: 0004449
2014-03-19 16:30 wandererfan Note Added: 0004477
2014-03-20 19:48 wandererfan File Added: LegoMst0001NewOCC.png
2014-03-20 19:55 wandererfan Note Added: 0004482
2014-04-25 10:58 wandererfan Note Added: 0004574
2014-04-25 10:58 wandererfan Status new => closed
2014-04-25 10:58 wandererfan Assigned To => wandererfan
2014-04-25 10:58 wandererfan Resolution open => no change required
