| 0000147 | FreeCAD | Feature | public | 2010-08-28 15:27 | 2010-09-06 18:49 |
| Reporter | normandc | Assigned To | yorik | ||
| Summary | 0000147: Keep Dimension tool active after completing instead of quitting | ||||
| Description | Dimensioning is frequently done only after drafting of a series of objects is completed. In such a case the Dimension tool has to be started repeatedly. Keeping the command active in a similar way to the Multi-point Wire tool would enhance its usability. | ||||
Very good idea! I'll do that. It'll also be a good opportunity to think of a better behaviour to "finish" commands (other than the poor "finish" button I did on the Wire tool, which cannot have a standard keyboard shortcut) |
done in r3536 might benefit some further improvement, but it works... |
| 2010-08-28 15:27 | normandc | New Issue | |
| 2010-09-01 07:26 |
Status | new => assigned |
| 2010-09-01 07:26 |
Assigned To | => yorik |
| 2010-09-01 10:50 | unauthenticated | Note Added: 0000315 | |
| 2010-09-06 18:49 | yorik | Note Added: 0000317 | |
| 2010-09-06 18:49 | yorik | Status | assigned => closed |
| 2010-09-06 18:49 | yorik | Resolution | open => fixed |
| 2010-09-06 18:49 | yorik | Fixed in Version | => 0.11 |
