| 0001470 | FreeCAD | Bug | public | 2014-03-10 05:07 | 2014-03-11 01:28 |
| Reporter | sdavies | Assigned To | yorik | ||
| OS | Linux | OS Version | Fedora 20 | ||
| Summary | 0001470: No module called pivy | ||||
| Description | OS: Linux Platform: 64-bit Version: 0.14.3285 (Git) Branch: master Hash: 664c50b6b6b0c50a4825f52accc1921204c4f3b3 Python version: 2.7.5 Qt version: 4.8.5 Coin version: 3.1.3 SoQt version: 1.5.0 Traceback (most recent call last): File "/home/scldad/.FreeCAD/aerofoil.FCMacro", line 16, in <module> import FreeCAD, FreeCADGui, Draft File "/usr/local/Mod/Draft/Draft.py", line 4748, in <module> import DraftSnap File "/usr/local/Mod/Draft/DraftSnap.py", line 29, in <module> import FreeCAD, FreeCADGui, math, Draft, DraftGui, DraftTrackers, DraftVecUtils File "/usr/local/Mod/Draft/DraftTrackers.py", line 30, in <module> from pivy import coin <type 'exceptions.ImportError'>: No module named pivy | ||||
| Steps To Reproduce | FreeCAD built from scratch using embedded pivy. Try to execute the aerofoil_import macro. The weird thing is that it works if I run .../freecad-build/bin/FreeCAD but not if I run /usr/local/bin/FreeCAD. Maybe something in the make install??? /usr/local/bin/pivy exists and contains coin.py. (It also works with both executables at build 3202.) | ||||
Resolved. It is necessary to invoke FreeCAD with a full path to enable it to find the pivy module. Changing the invocation to /usr/local/bin/FreeCAD rather than just FreeCAD makes it work. |
Good, then I'll close the issue! |
| 2014-03-10 05:07 | sdavies | New Issue | |
| 2014-03-10 06:16 | sdavies | Note Added: 0004402 | |
| 2014-03-11 01:28 | yorik | Note Added: 0004409 | |
| 2014-03-11 01:28 | yorik | Status | new => closed |
| 2014-03-11 01:28 | yorik | Assigned To | => yorik |
| 2014-03-11 01:28 | yorik | Resolution | open => no change required |
| 2014-03-11 01:28 | yorik | Fixed in Version | => 0.14 |
