| 0001471 | Arch | Feature | public | 2014-03-11 01:25 | 2014-07-20 21:30 |
| Target Version | 0.15 | Fixed in Version | 0.15 | ||
| Summary | 0001471: Arch - Panel object | ||||
| Description | 1) a special arch object to represent a panel component (renamed from wikihouse, since many other techniques use this). It must have: - a base profile - a thickness property - a number of plywood sheets to use - an inscription (id number to be engraved) with position 2) a view object that shows the base profile with engraving 3) a SVG template that represents a plywood sheet 4) possibility to output to DXF | ||||
http://www.wikihouse.cc/ |
Basically implemented. Engraving stuff is still not included, since I have not much idea yet on how it should behave. |
FreeCAD: master 6c8c69df 2014-07-20 18:19:51 Details Diff |
Arch: small fix in panel |
Affected Issues 0001471 |
| mod - src/Mod/Arch/ArchPanel.py | Diff File | ||
FreeCAD: master 4414da22 2014-07-20 18:28:43 Details Diff |
Arch: Updated preferences page for panels |
| mod - src/Mod/Arch/ArchCommands.py | Diff File | ||
| mod - src/Mod/Arch/Arch_rc.py | Diff File | ||
| mod - src/Mod/Arch/Resources/ui/archprefs-defaults.ui | Diff File | ||
FreeCAD: master a0bb761d 2014-07-20 18:32:06 Details Diff |
Arch: added panel to cmakelist |
| mod - src/Mod/Arch/CMakeLists.txt | Diff File | ||
| 2014-03-11 01:25 | yorik | New Issue | |
| 2014-03-11 01:25 | yorik | Status | new => assigned |
| 2014-03-11 01:25 | yorik | Assigned To | => yorik |
| 2014-03-11 01:26 | yorik | Project | FreeCAD => Arch |
| 2014-04-01 02:00 | yorik | Summary | Arch - WikiHouse object => Arch - Panel object |
| 2014-04-01 02:00 | yorik | Description Updated | |
| 2014-04-06 16:18 | yorik | Note Added: 0004536 | |
| 2014-07-06 15:26 | yorik | Target Version | => 0.15 |
| 2014-07-20 21:28 | yorik | Changeset attached | => FreeCAD Master master a0bb761d |
| 2014-07-20 21:29 | yorik | Changeset attached | => FreeCAD Master master 4414da22 |
| 2014-07-20 21:29 | yorik | Changeset attached | => FreeCAD Master master 6c8c69df |
| 2014-07-20 21:30 | yorik | Note Added: 0004820 | |
| 2014-07-20 21:30 | yorik | Status | assigned => closed |
| 2014-07-20 21:30 | yorik | Resolution | open => fixed |
| 2014-07-20 21:30 | yorik | Fixed in Version | => 0.15 |
